Up to 20% off select tools
Google Pixel 10 Battery Replacement
Views: 13K
View statistics:
Past 24 Hours:
44
Past 7 Days:
245
Past 30 Days:
923
All Time:
12,577
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace a dead or worn‑out battery in your Google Pixel 10.
All smartphone batteries have limited lifespans. If your phone doesn't hold a charge or dies unexpectedly, it might be time to replace the battery.
If your battery is swollen, take appropriate precautions.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair depends on how accurately the new adhesives are applied and how clean the surfaces are.
    1. Google Pixel 10 Battery Replacement, Prepare your Pixel for disassembly: step 1, image 1 of 1
      • Unplug all cables from your phone.
      • Let your Pixel's battery drain completely (until it dies) before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      Ask FixBot
    1. Google Pixel 10 Battery Replacement, Cracked glass preparation: step 2, image 1 of 3 Google Pixel 10 Battery Replacement, Cracked glass preparation: step 2, image 2 of 3 Google Pixel 10 Battery Replacement, Cracked glass preparation: step 2, image 3 of 3
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone's back glass is cracked, follow this step.
      • Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
      • Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
      • Only cover the glass itself—don't stick any tape to the frame.
      • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    2. Google Pixel 10 Battery Replacement, Heat the bottom edge: step 3, image 1 of 1
      • Adhesive secures the back glass to the frame. Heating the glass softens the adhesive, making it easier to separate.
      • Heat an iOpener and lay it on the bottom edge of the back glass for two minutes.
      • Alternatively, you can use a hair dryer or heat gun to heat the back glass.
      • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
      Ask FixBot
    3. Google Pixel 10 Battery Replacement, Apply a suction handle: step 4, image 1 of 2 Google Pixel 10 Battery Replacement, Apply a suction handle: step 4, image 2 of 2
      • Apply a suction handle to the center of the back glass's bottom edge, as close to the edge as possible.
      Ask FixBot
    4. Google Pixel 10 Battery Replacement, Insert an opening pick: step 5, image 1 of 3 Google Pixel 10 Battery Replacement, Insert an opening pick: step 5, image 2 of 3 Google Pixel 10 Battery Replacement, Insert an opening pick: step 5, image 3 of 3
      • Pull up on the suction handle with strong, steady force until a gap forms between the back glass and frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    5. Google Pixel 10 Battery Replacement, Back glass adhesive information: step 6, image 1 of 3 Google Pixel 10 Battery Replacement, Back glass adhesive information: step 6, image 2 of 3 Google Pixel 10 Battery Replacement, Back glass adhesive information: step 6, image 3 of 3
      • The back glass is secured with adhesive around the perimeter of the frame. Use this picture as a reference while you separate the adhesive.
      • A cable connects the back glass near the power button. Don't insert your pick here to avoid damaging the cable.
      Ask FixBot
    6. Google Pixel 10 Battery Replacement, Separate the bottom edge adhesive: step 7, image 1 of 3 Google Pixel 10 Battery Replacement, Separate the bottom edge adhesive: step 7, image 2 of 3 Google Pixel 10 Battery Replacement, Separate the bottom edge adhesive: step 7, image 3 of 3
      • If the back glass feels stuck at any point when separating the adhesive, apply heat to the area and try again.
      • Slide the opening pick along the bottom edge to separate the adhesive.
      • Leave the pick inserted under the bottom left corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    7. Google Pixel 10 Battery Replacement, Separate the bottom left adhesive: step 8, image 1 of 3 Google Pixel 10 Battery Replacement, Separate the bottom left adhesive: step 8, image 2 of 3 Google Pixel 10 Battery Replacement, Separate the bottom left adhesive: step 8, image 3 of 3
      • Insert a second pick under the bottom left corner and slide it up the left edge, stopping at the power button.
      • Leave the pick inserted to prevent the adhesive from re‑sealing.
      Ask FixBot
    8. Google Pixel 10 Battery Replacement, Separate the right edge adhesive: step 9, image 1 of 3 Google Pixel 10 Battery Replacement, Separate the right edge adhesive: step 9, image 2 of 3 Google Pixel 10 Battery Replacement, Separate the right edge adhesive: step 9, image 3 of 3
      • Insert a third pick under the bottom right corner of the back glass and slide it up the right edge.
      • Leave the pick inserted under the top right corner.
      Ask FixBot
    9. Google Pixel 10 Battery Replacement, Separate the top edge adhesive: step 10, image 1 of 3 Google Pixel 10 Battery Replacement, Separate the top edge adhesive: step 10, image 2 of 3 Google Pixel 10 Battery Replacement, Separate the top edge adhesive: step 10, image 3 of 3
      • Insert a fourth pick under the top right corner.
      • Slide the pick along the top edge and slightly around the top left corner, stopping at the bottom of the camera bump.
      • Don't try to fully remove the back glass yet, as it's still connected by a ribbon cable.
      Ask FixBot
    10. Google Pixel 10 Battery Replacement, Prop up the back glass: step 11, image 1 of 3 Google Pixel 10 Battery Replacement, Prop up the back glass: step 11, image 2 of 3 Google Pixel 10 Battery Replacement, Prop up the back glass: step 11, image 3 of 3
      • Flip the back glass over the left side of the phone and use the suction handle (or a sturdy object) to prop it up.
      • If the back glass still feels stuck, go back around the perimeter with an opening pick and separate any remaining adhesive.
      Ask FixBot
    11. Google Pixel 10 Battery Replacement, Remove the bracket screws: step 12, image 1 of 2 Google Pixel 10 Battery Replacement, Remove the bracket screws: step 12, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to remove the two 5.0 mm‑long screws securing the back glass connector bracket.
      Ask FixBot
    12. Google Pixel 10 Battery Replacement: step 13, image 1 of 3 Google Pixel 10 Battery Replacement: step 13, image 2 of 3 Google Pixel 10 Battery Replacement: step 13, image 3 of 3
      • Use tweezers or your fingers to remove the bracket.
      • Be careful not to scratch or smudge the rear cameras.
      Ask FixBot
    13. Google Pixel 10 Battery Replacement, Disconnect the back glass: step 14, image 1 of 2 Google Pixel 10 Battery Replacement, Disconnect the back glass: step 14, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the back glass press connector.
      Ask FixBot
    14. Google Pixel 10 Battery Replacement, Remove the back glass: step 15, image 1 of 1
      • Remove the back glass.
      Ask FixBot
    1. Google Pixel 10 Battery Replacement, Remove the motherboard cover screws: step 16, image 1 of 2 Google Pixel 10 Battery Replacement, Remove the motherboard cover screws: step 16, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to remove the two 5.0 mm‑long screws securing the motherboard cover.
      Ask FixBot
    2. Google Pixel 10 Battery Replacement, Remove the motherboard cover: step 17, image 1 of 3 Google Pixel 10 Battery Replacement, Remove the motherboard cover: step 17, image 2 of 3 Google Pixel 10 Battery Replacement, Remove the motherboard cover: step 17, image 3 of 3
      • Use a spudger to lift the motherboard cover, then grip the cover and slowly peel the graphite sheet off the battery.
      Ask FixBot
    3. Google Pixel 10 Battery Replacement, Disconnect the battery: step 18, image 1 of 2 Google Pixel 10 Battery Replacement, Disconnect the battery: step 18, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    4. Google Pixel 10 Battery Replacement, Disconnect the interconnect cable: step 19, image 1 of 2 Google Pixel 10 Battery Replacement, Disconnect the interconnect cable: step 19, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the interconnect cable press connector from the bottom right of the motherboard.
      Ask FixBot
    5. Google Pixel 10 Battery Replacement, Remove the USB‑C board cover: step 20, image 1 of 2 Google Pixel 10 Battery Replacement, Remove the USB‑C board cover: step 20, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to remove the two 5.0 mm‑long screws securing the USB‑C board cover.
      Ask FixBot
    6. Google Pixel 10 Battery Replacement: step 21, image 1 of 3 Google Pixel 10 Battery Replacement: step 21, image 2 of 3 Google Pixel 10 Battery Replacement: step 21, image 3 of 3
      • Remove the USB‑C board cover.
      Ask FixBot
    7. Google Pixel 10 Battery Replacement, Disconnect the interconnect cable: step 22, image 1 of 2 Google Pixel 10 Battery Replacement, Disconnect the interconnect cable: step 22, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the interconnect cable press connector from the USB‑C board.
      Ask FixBot
    8. Google Pixel 10 Battery Replacement, Remove the interconnect cable: step 23, image 1 of 2 Google Pixel 10 Battery Replacement, Remove the interconnect cable: step 23, image 2 of 2
      • Remove the interconnect cable.
      Ask FixBot
    9. Google Pixel 10 Battery Replacement, Peel up the battery pull tab: step 24, image 1 of 3 Google Pixel 10 Battery Replacement, Peel up the battery pull tab: step 24, image 2 of 3 Google Pixel 10 Battery Replacement, Peel up the battery pull tab: step 24, image 3 of 3
      • Use your fingers to peel up the entire battery tab on the left side of the battery, including the skinny strip running along the side.
      Ask FixBot
    10. Google Pixel 10 Battery Replacement, Use finger stalls: step 25, image 1 of 1
      Tool used on this step:
      Finger Stalls
      $8.99
      Buy
      Ask FixBot
    11. Google Pixel 10 Battery Replacement, Separate the battery adhesive: step 26, image 1 of 3 Google Pixel 10 Battery Replacement, Separate the battery adhesive: step 26, image 2 of 3 Google Pixel 10 Battery Replacement, Separate the battery adhesive: step 26, image 3 of 3
      • Secure the right side of your phone with one hand, and use your free hand to grip the battery pull tab.
      • Make sure your hand securing the phone is mainly pressing on the frame—it shouldn't be covering the battery or pressing down on delicate components.
      • Pull straight up on the tab and apply constant, steady force until the adhesive separates.
      Ask FixBot
    12. Google Pixel 10 Battery Replacement, Remove the battery: step 27, image 1 of 3 Google Pixel 10 Battery Replacement, Remove the battery: step 27, image 2 of 3 Google Pixel 10 Battery Replacement, Remove the battery: step 27, image 3 of 3
      • Grip the battery and slowly pull it away from your phone to peel the plastic sleeve out of the recess.
      • Remove the battery.
      Ask FixBot
    1. Google Pixel 10 Battery Replacement, Disassembly complete: step 28, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your phone.
      Ask FixBot
    1. Google Pixel 10 Battery Replacement, Clean the battery recess: step 29, image 1 of 3 Google Pixel 10 Battery Replacement, Clean the battery recess: step 29, image 2 of 3 Google Pixel 10 Battery Replacement, Clean the battery recess: step 29, image 3 of 3
      • Before installing a new battery, check the recess for leftover bits of plastic, as well as adhesive residue from the battery sleeve.
      • If the battery came out cleanly, you can skip this step.
      • Remove any bits of plastic from the old battery sleeve.
      • Use one or two drops high‑concentration (>90%) isopropyl alcohol and a microfiber or lint‑free cloth to clean up any adhesive residue.
      • Be careful not to get alcohol in the cutouts in the battery recess—the bottom of the screen is exposed and may get damaged.
      • Allow the alcohol to dry completely before continuing.
      Ask FixBot
    2. Google Pixel 10 Battery Replacement, Remove the battery liner: step 30, image 1 of 1
      • Remove the large, colored liner from the battery to expose the adhesive.
      Ask FixBot
    3. Google Pixel 10 Battery Replacement, Install the battery: step 31, image 1 of 3 Google Pixel 10 Battery Replacement, Install the battery: step 31, image 2 of 3 Google Pixel 10 Battery Replacement, Install the battery: step 31, image 3 of 3
      • Hold the battery above its recess and use your finger to push down and reconnect the battery press connector.
      • Temporarily reconnecting the battery ensures that it's sitting properly in its recess.
      • Lay the battery into its recess and press down firmly to secure it.
      Ask FixBot
    4. Google Pixel 10 Battery Replacement, Disconnect the battery: step 32, image 1 of 2 Google Pixel 10 Battery Replacement, Disconnect the battery: step 32, image 2 of 2
      Ask FixBot
    5. Google Pixel 10 Battery Replacement, Remove any remaining liners: step 33, image 1 of 2 Google Pixel 10 Battery Replacement, Remove any remaining liners: step 33, image 2 of 2
      • Use your fingers to remove any remaining stickers or liners from the battery.
      Ask FixBot
    6. Google Pixel 10 Battery Replacement, Install the interconnect cable: step 34, image 1 of 2 Google Pixel 10 Battery Replacement, Install the interconnect cable: step 34, image 2 of 2
      • Lay the interconnect cable back in place, making sure the connectors line up with their sockets.
      Ask FixBot
    7. Google Pixel 10 Battery Replacement, Connect the interconnect cable: step 35, image 1 of 2 Google Pixel 10 Battery Replacement, Connect the interconnect cable: step 35, image 2 of 2
      • Use your finger to press down and reconnect the interconnect cable press connector to its socket on the motherboard.
      Ask FixBot
    8. Google Pixel 10 Battery Replacement: step 36, image 1 of 2 Google Pixel 10 Battery Replacement: step 36, image 2 of 2
      • Use your finger to press down and reconnect the interconnect cable press connector to its socket on the USB‑C board.
      Ask FixBot
    9. Google Pixel 10 Battery Replacement, Install the USB‑C board cover: step 37, image 1 of 3 Google Pixel 10 Battery Replacement, Install the USB‑C board cover: step 37, image 2 of 3 Google Pixel 10 Battery Replacement, Install the USB‑C board cover: step 37, image 3 of 3
      • Put the USB‑C board cover back into place, sliding the tabs on the top corners under their hooks.
      Ask FixBot
    10. Google Pixel 10 Battery Replacement: step 38, image 1 of 2 Google Pixel 10 Battery Replacement: step 38, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the USB‑C board cover.
      Ask FixBot
    11. Google Pixel 10 Battery Replacement, Replace the thermal pad: step 39, image 1 of 3 Google Pixel 10 Battery Replacement, Replace the thermal pad: step 39, image 2 of 3 Google Pixel 10 Battery Replacement, Replace the thermal pad: step 39, image 3 of 3
      • Check the condition of the motherboard thermal pad—it'll either be on the bottom edge of the board or on the underside of the cover.
      • If the thermal pad is damaged, follow the next three steps to replace it. Otherwise, skip down three steps.
      • Use the flat end of a spudger to gently scrape up and remove all the old thermal pad from the board and cover.
      Ask FixBot
    12. Google Pixel 10 Battery Replacement: step 40, image 1 of 2 Google Pixel 10 Battery Replacement: step 40, image 2 of 2
      • Use high‑concentration (>90%) isopropyl alcohol and a coffee filter (or lint‑free cloth) to clean up any thermal pad residue from the board and cover.
      Ask FixBot
    13. Google Pixel 10 Battery Replacement: step 41, image 1 of 3 Google Pixel 10 Battery Replacement: step 41, image 2 of 3 Google Pixel 10 Battery Replacement: step 41, image 3 of 3
      • Remove the larger liner (without cutouts) from the thermal pad.
      • Lay the thermal pad in its square cutout on the underside of the motherboard cover.
      • Press down firmly on the entire surface of the pad with your finger or the flat end of a spudger.
      • Slowly peel up the remaining liner.
      • If the pad starts to peel up with the liner, press it back into place and try again.
      Ask FixBot
    14. Google Pixel 10 Battery Replacement, Connect the battery: step 42, image 1 of 1
      • Use your finger to press down and reconnect the battery press connector.
      Ask FixBot
    15. Google Pixel 10 Battery Replacement, Check the graphite sheet: step 43, image 1 of 2 Google Pixel 10 Battery Replacement, Check the graphite sheet: step 43, image 2 of 2
      • Check the condition of the graphite sheet attached to the motherboard cover.
      • If the sheet is torn or damaged in any way, peel it up and remove it from the cover—you'll apply a new one in a few steps.
      Ask FixBot
    16. Google Pixel 10 Battery Replacement, Install the motherboard cover: step 44, image 1 of 2 Google Pixel 10 Battery Replacement, Install the motherboard cover: step 44, image 2 of 2
      • Put the motherboard cover back in place.
      Ask FixBot
    17. Google Pixel 10 Battery Replacement: step 45, image 1 of 2 Google Pixel 10 Battery Replacement: step 45, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the motherboard cover.
      Ask FixBot
    18. Google Pixel 10 Battery Replacement, Prepare the graphite sheet: step 46, image 1 of 1
      • Remove the large clear liner from the graphite sheet, exposing the adhesive.
      Ask FixBot
    19. Google Pixel 10 Battery Replacement, Install the graphite sheet: step 47, image 1 of 3 Google Pixel 10 Battery Replacement, Install the graphite sheet: step 47, image 2 of 3 Google Pixel 10 Battery Replacement, Install the graphite sheet: step 47, image 3 of 3
      • Lay the graphite sheet into place, so the circular portion is over the battery, and the cutouts on the top edge go into the grooves on the motherboard cover.
      • Use your fingers to press down firmly on the entire surface of the sheet to secure it.
      Ask FixBot
    20. Google Pixel 10 Battery Replacement: step 48, image 1 of 3 Google Pixel 10 Battery Replacement: step 48, image 2 of 3 Google Pixel 10 Battery Replacement: step 48, image 3 of 3
      • Slowly peel up and remove the remaining liner.
      • If the sheet starts to peel up with the liner, press it back into place and try again.
      Ask FixBot
    1. Google Pixel 10 Battery Replacement, Remove the old back glass adhesive: step 49, image 1 of 2 Google Pixel 10 Battery Replacement, Remove the old back glass adhesive: step 49, image 2 of 2
      • Before installing new adhesive, all the old adhesive and its residue must be completely removed from the frame.
      • Take your time during the next two steps. A clean frame allows replacement adhesive to lay totally flat, ensuring a better seal for your back glass.
      Ask FixBot
    2. Google Pixel 10 Battery Replacement: step 50, image 1 of 3 Google Pixel 10 Battery Replacement: step 50, image 2 of 3 Google Pixel 10 Battery Replacement: step 50, image 3 of 3
      • Removing all the old adhesive can be very tricky and time‑consuming.
      • When removing the back glass adhesive during this step, be very careful not to damage the battery or any of the fragile components near the perimeter of the frame.
      • Use the point of a spudger to remove all the old screen adhesive from the frame. Try to "roll" the adhesive onto itself so it balls up, making it easier to remove.
      • If you're having trouble removing smaller chunks, apply a single drop of high‑concentration (>90%) isopropyl alcohol and scrape them up with your spudger.
      Ask FixBot
    3. Google Pixel 10 Battery Replacement: step 51, image 1 of 2 Google Pixel 10 Battery Replacement: step 51, image 2 of 2
      • Wrap a microfiber or lint‑free cloth around a spudger and apply a single drop of high‑concentration (>90%) isopropyl alcohol to the end.
      • Use the spudger to clean up all the remaining adhesive residue from the frame, applying more drops of alcohol as necessary.
      • Let the alcohol dry completely before continuing.
      Ask FixBot
    4. Google Pixel 10 Battery Replacement: step 52, image 1 of 2 Google Pixel 10 Battery Replacement: step 52, image 2 of 2
      • If you're reinstalling your original back glass, repeat the procedures in the previous two steps on the back glass to clean it.
      Ask FixBot
    5. Google Pixel 10 Battery Replacement, Orient the adhesive: step 53, image 1 of 2 Google Pixel 10 Battery Replacement, Orient the adhesive: step 53, image 2 of 2
      • Before applying the back glass adhesive, make sure you know how it will sit on the frame. If you apply the adhesive incorrectly, you'll need to restart with new adhesive.
      • Hold the adhesive above the frame to find its orientation. Use the rear camera cutout in the liner to help visualize how it will lay in the frame.
      Ask FixBot
    6. Google Pixel 10 Battery Replacement: step 54, image 1 of 1
      • Peel down the top half of the large, clear liner to expose the adhesive—don't fully remove the liner yet.
      Ask FixBot
    7. Google Pixel 10 Battery Replacement, Install the back glass adhesive: step 55, image 1 of 3 Google Pixel 10 Battery Replacement, Install the back glass adhesive: step 55, image 2 of 3 Google Pixel 10 Battery Replacement, Install the back glass adhesive: step 55, image 3 of 3
      • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
      • With the larger, clear liner folded towards the bottom of the phone, lay the exposed top edge of the adhesive onto the frame.
      • Use the lip of the frame to help align the adhesive.
      • Once the top edge is properly aligned, gently press down on the top corners to secure the adhesive.
      Ask FixBot
    8. Google Pixel 10 Battery Replacement: step 56, image 1 of 3 Google Pixel 10 Battery Replacement: step 56, image 2 of 3 Google Pixel 10 Battery Replacement: step 56, image 3 of 3
      • Slowly lay the rest of the adhesive onto the frame, pressing it into place and peeling away the larger liner as you go.
      Ask FixBot
    9. Google Pixel 10 Battery Replacement: step 57, image 1 of 3 Google Pixel 10 Battery Replacement: step 57, image 2 of 3 Google Pixel 10 Battery Replacement: step 57, image 3 of 3
      • Use a spudger to press down firmly on the adhesive to secure it to the frame.
      Ask FixBot
    10. Google Pixel 10 Battery Replacement, Remove the larger liner: step 58, image 1 of 3 Google Pixel 10 Battery Replacement, Remove the larger liner: step 58, image 2 of 3 Google Pixel 10 Battery Replacement, Remove the larger liner: step 58, image 3 of 3
      • Slowly peel up and remove the large colored liner, gripping it from the cutout near the top edge.
      • If the adhesive starts to peel up with the liner, check that you’ve pushed all of it into place with your spudger. If it continues to peel up, hold it down with the point of your spudger as you go.
      Ask FixBot
    11. Google Pixel 10 Battery Replacement: step 59, image 1 of 3 Google Pixel 10 Battery Replacement: step 59, image 2 of 3 Google Pixel 10 Battery Replacement: step 59, image 3 of 3
      Ask FixBot
    12. Google Pixel 10 Battery Replacement, Remove any liners from the back glass: step 60, image 1 of 2 Google Pixel 10 Battery Replacement, Remove any liners from the back glass: step 60, image 2 of 2
      • If you're installing a new back glass, your replacement will have various protective liners and pieces of tape on the underside that must be removed. Your part may have different pieces in different locations, so make sure to check carefully!
      • Remove all liners from the underside of the back glass, paying special attention to the front camera cutouts and bottom edge.
      • Usually, you can identify the liners by their pull tabs.
      Ask FixBot
    13. Google Pixel 10 Battery Replacement, Prop up the back glass: step 61, image 1 of 1
      • Apply a suction handle to the back glass and prop it up on the left side of your phone, so the cable is near its connector.
      • Alternatively, you can use a sturdy object (such as a stack of books) to prop up the back glass.
      Ask FixBot
    14. Google Pixel 10 Battery Replacement, Connect the back glass cable: step 62, image 1 of 2 Google Pixel 10 Battery Replacement, Connect the back glass cable: step 62, image 2 of 2
      • Use the flat end of a spudger to connect the back glass press connector to its socket.
      • This can be tricky, as there's very little play in the cable. Move the back glass as necessary to help, and don't try to force the connector into place—reposition it and try again.
      Ask FixBot
    15. Google Pixel 10 Battery Replacement, Install the bracket: step 63, image 1 of 3 Google Pixel 10 Battery Replacement, Install the bracket: step 63, image 2 of 3 Google Pixel 10 Battery Replacement, Install the bracket: step 63, image 3 of 3
      • Put the cable's bracket back in place, making sure the tab on the right edge goes under its groove.
      Ask FixBot
    16. Google Pixel 10 Battery Replacement: step 64, image 1 of 2 Google Pixel 10 Battery Replacement: step 64, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to install the two 5.0 mm‑long screws securing the bracket.
      • This is a good point to power on your device and test all functions before sealing it up. If you have trouble, try some basic troubleshooting. Be sure to power back down completely before you continue working.
      Ask FixBot
    17. Google Pixel 10 Battery Replacement, Remove the remaining liners: step 65, image 1 of 3 Google Pixel 10 Battery Replacement, Remove the remaining liners: step 65, image 2 of 3 Google Pixel 10 Battery Replacement, Remove the remaining liners: step 65, image 3 of 3
      • Remove the remaining liners from the back glass adhesive.
      Ask FixBot
    18. Google Pixel 10 Battery Replacement, Install the back glass: step 66, image 1 of 3 Google Pixel 10 Battery Replacement, Install the back glass: step 66, image 2 of 3 Google Pixel 10 Battery Replacement, Install the back glass: step 66, image 3 of 3
      • Flip the back glass onto the frame and press it firmly into place.
      • Hold your phone up and squeeze firmly around the perimeter to strengthen the bond.
      • For an even stronger bond, you can stack books on the back glass or use screen vise clamps.
      Ask FixBot
Congratulations on completing your repair!
For optimal performance, calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
210,836 Reputation
1,265 Guides authored
2 Guide Comments
I am for India India's to delivery
Asif Asif - Reply Share
Am I missing something or should Step 48 come around the same time as Step 65? Does the removal of the blue film in Step 48 reveal adhesive that's not used until the back glass is put on? Or is there just no adhesive under that blue film in Step 48?
Lord Jair - Reply Share
Past 24 Hours: 44
Past 7 Days: 245
Past 30 Days: 923
All Time: 12,577
