Up to 20% off select tools
Geek Bar Pulse Refill
Views: 14K
View statistics:
Past 24 Hours:
53
Past 7 Days:
364
Past 30 Days:
1,624
All Time:
13,817
Comments: 9
3 comments on steps, 6 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Although these devices are well made and work amazingly, it's disappointing that they simply make their way into the garbage once they're empty.
It is, however, possible to refill these with your favorite flavor of ejuice, and this guide will show you the right way to go about it.
Three or four refills are all that are recommended; after that the heater coils get too gummed up with carbon and the cotton gets burnt, resulting in bad flavor and poor vapor production.
If you're considering refilling your vape for the first time, be sure to stop using it just as soon as you start tasting a burn flavor. A couple of pulls that taste burnt won't hurt anything, but if you continue you'll burn the cotton and possibly burn out a coil.
    1. Geek Bar Pulse Refill, Remove the Mouthpiece: step 1, image 1 of 2 Geek Bar Pulse Refill, Remove the Mouthpiece: step 1, image 2 of 2
      • Grasp the mouthpiece with a pair of pliers.
      • Give it a good, solid twist, left or right doesn't matter.
      • The pliers won't damage the silicone coating on the mouthpiece, but faint marks may be visible.
      Ask FixBot
    2. Geek Bar Pulse Refill, The Mouthpiece Seal: step 2, image 1 of 3 Geek Bar Pulse Refill, The Mouthpiece Seal: step 2, image 2 of 3 Geek Bar Pulse Refill, The Mouthpiece Seal: step 2, image 3 of 3
      • Hopefully the mouthpiece seal stays in place when you removed the mouthpiece, but it doesn't always. If it has come off, you need to know how to replace it.
      • It is inserted into the mouthpiece with the felt piece up. Putting it in the other way will not allow for an airtight seal between the tank and the mouthpiece.
      • When you reassemble your vape, be sure to test it by turning the power switch off, then sucking on the mouthpiece. If you can get any air at all through, you've got the seal in wrong.
      Ask FixBot
    3. Geek Bar Pulse Refill, Replacing the Mouthpiece: step 3, image 1 of 2 Geek Bar Pulse Refill, Replacing the Mouthpiece: step 3, image 2 of 2
      • Note that the mouthpiece has a tab that only allows it to be mounted in one orientation. The arrow here points to the one you'll need to match up with on the case.
      • Here you can see inside the case where the tab on the mouthpiece lines up.
      Ask FixBot
    1. Geek Bar Pulse Refill, Switch the Vape Off: step 4, image 1 of 1
      • Turn the power switch to the Off position; no air holes should be visible.
      Ask FixBot
    2. Geek Bar Pulse Refill, Remove the Power Button: step 5, image 1 of 3 Geek Bar Pulse Refill, Remove the Power Button: step 5, image 2 of 3 Geek Bar Pulse Refill, Remove the Power Button: step 5, image 3 of 3
      • Use your utility knife to lever the power button up. It is only pressed on, so there is no adhesive or clips to deal with.
      • Remove the power button.
      • Since the creation of this guide, I have found that on newer models it appears the manufacturer has started gluing the buttons on, presumably to keep them from falling off. The instructions will still work, but requires more effort to remove the button and you may need to glue it back on.
      Ask FixBot
    3. Geek Bar Pulse Refill: step 6, image 1 of 3 Geek Bar Pulse Refill: step 6, image 2 of 3 Geek Bar Pulse Refill: step 6, image 3 of 3
      • Position your thumbnail on the seam near the bottom of the vape.
      • Work your utility knife into the two high points of the case on the bottom.
      • Pry the near side of the case far enough open to get your fingernail into the gap to keep it open.
      Ask FixBot
    4. Geek Bar Pulse Refill: step 7, image 1 of 3 Geek Bar Pulse Refill: step 7, image 2 of 3 Geek Bar Pulse Refill: step 7, image 3 of 3
      • Insert your knife and slide it down, then use it to lever the top of the vape out of the case.
      • Using the knife, go back to the bottom and lever the opposite side out.
      • On the other side, insert the knife and use it to pop the clips on that side.
      Ask FixBot
    5. Geek Bar Pulse Refill, Remove the Cover: step 8, image 1 of 2 Geek Bar Pulse Refill, Remove the Cover: step 8, image 2 of 2
      • The clips should be free all the way around at this point.
      • Pull the vape straight out of the case.
      Ask FixBot
    6. Geek Bar Pulse Refill: step 9, image 1 of 1
      • The cover has been removed.
      Ask FixBot
    1. Geek Bar Pulse Refill, Geek Bar Pulse Refill: step 10, image 1 of 2 Geek Bar Pulse Refill, Geek Bar Pulse Refill: step 10, image 2 of 2
      • When filling the vape, try to avoid getting your liquid down the center tube. A small amount won't hurt anything, but too much can end up running out the bottom, dripping and getting into the electronics. If that happens, turn the vape upside down, turn it onto the Pulse setting and blow into the switch.
      • Start with pressing the tip of your bottle or syringe on top of the foam. Aim it toward the side and fill until the top of the vape fills with liquid, then stop.
      • In the second picture you can see the liquid spreading out into the foam and filling the space between the foam and the clear case.
      Ask FixBot
    2. Geek Bar Pulse Refill: step 11, image 1 of 3 Geek Bar Pulse Refill: step 11, image 2 of 3 Geek Bar Pulse Refill: step 11, image 3 of 3
      • Move to one of the sides to continue filling.
      • ...And continue to the next side.
      • And finally the last side.
      Ask FixBot
    3. Geek Bar Pulse Refill: step 12, image 1 of 3 Geek Bar Pulse Refill: step 12, image 2 of 3 Geek Bar Pulse Refill: step 12, image 3 of 3
      • Here you can see the liquid as it soaks into the foam.
      • Continue filling on all four sides.
      • Stop when you get to about 2/3rd of the way down; the liquid will continue to spread through the foam. Too much will again end up dripping.
      Ask FixBot
9 other people completed this guide.
Author
with
Jerry Wheeler
103,496 Reputation
97 Guides authored
6 Guide Comments
It's not burning out it's the counter ran out so now it does the light instead of the electricity like it only we could reset the counter... Once it runs down even though it worked perfect 2 seconds before, poof. Lights of death as they call them on xbox with the ring of light.... I loved the crap out of mine it's too bad! Ill still use the cotton somehow in another device I guess. Maybe if I disconnect the screen altogether and just have the battery on it isnt that he black cord their always colorful but it's bound to work like a screenless counter less draw activated....or is it the electricity were enjoying eating on ha. Yum.
artSu Elove - Reply Share
Based on my experience with the Pulse vapes, you've got a burnt out coil. I've noted two different conditions where the outer ring flashes red; the first is after you've taken a hit when the counter is at zero; it flashes red for a moment after you've finished drawing, but that doesn't seem to affect the operation in any way.
The second condition where it flashes red is when one or both of the coils is reading wildly out of spec. I've seen them measure on the order of 30 ohms when they should be showing somewhere between 1.2 and 1.5 ohms. When that happens, the flashing will happen as you're drawing air, and it won't heat during that time. The fix for that is to rebuild the coils; usually it's the lower one that goes out first, since that's the one that's used when you're in the normal rather than pulse mode.
Geek Bar Pulse Mesh Coil Rebuild - iFixit Repair Guide
As far as the counter, I haven't found or heard of a way to reset it, but I've refilled a Pulse several times and it doesn't affect anything.
Jerry Wheeler - Reply Share
Hi! My vape rapidly starts and stops after I refilled it. Im positive that some liquid got into its electronics. Is there any way to fix it? It also won't start when im sucking on the mouthpiece. It does releace smoke if I keep sucking on it while it keeps quickly turning on the heater for a split second.
Connor Waters - Reply Share
I’m not sure how I got here… but might as well ask a question…. I have a vape that still has visible liquid in the tank thing, draw on the vape… no smoke, no lights, blow into the opposite end like where the charger goes and smoke comes out of the top/mouthpuece. 🤷🏽‍♀️🤷🏽‍♀️🤷🏽‍♀️
tiffany carpenter - Reply Share
@tiffanycar26507 in my opinion, it sounds like an improper seal. Try reseating the mouth piece to see if that helps
Liam Neagle - Reply Share
Past 24 Hours: 53
Past 7 Days: 364
Past 30 Days: 1,624
All Time: 13,817
