Garmin Nuvi 370 Microphone Replacement
  1. Garmin Nuvi 370 Microphone Replacement, Microphone: step 1, image 1 of 1
    • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
    Ask FixBot
  2. Garmin Nuvi 370 Microphone Replacement: step 2, image 1 of 2 Garmin Nuvi 370 Microphone Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
    Ask FixBot
  3. Garmin Nuvi 370 Microphone Replacement: step 3, image 1 of 2 Garmin Nuvi 370 Microphone Replacement: step 3, image 2 of 2
    • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
    Ask FixBot
  4. Garmin Nuvi 370 Microphone Replacement: step 4, image 1 of 2 Garmin Nuvi 370 Microphone Replacement: step 4, image 2 of 2
    • Disconnect the speaker and battery from their terminals on the motherboard. This should disconnect the motherboard completely from the back panel.
    • This step is optional but is recommended as it will create more room to work.
    • It is recommended that you use tweezers or the spudger for precision.
    Ask FixBot
  5. Garmin Nuvi 370 Microphone Replacement: step 5, image 1 of 1
    • Gently pull out the microphone wire from the terminal. Tweezers are recommended for precision.
    Ask FixBot
  6. Garmin Nuvi 370 Microphone Replacement: step 6, image 1 of 1
    • The microphone component should now be completely separated from the motherboard.
    • Plug in new, functional microphone component.
    Ask FixBot
Finish Line
Matt West
31 Reputation
4 Guides authored
Cal Poly, Team 13-65, Johann Spring 2013 Member of Cal Poly, Team 13-65, Johann Spring 2013
CPSU-JOHANN-S13S13G65
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 684
