Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓This guide walks through the general disassembly of components that are required from installment.
Unscrew the two screws on the antenna unit using a torc-head screwdriver.
Gently pry open the antenna unit with your fingers.
Tool used on this step:Tweezers$4.99
Slide out the inner casing attached to the antenna body.
Remove the rotating joint connecting the antenna casing to the main device:
Squeeze tweezers into the shown location and compress the spring.
Lift out the outer casing while keeping the spring compressed.
2 other people completed this guide.
