GameSir Tarantula Pro Joystick Cover Replacement
    1. GameSir Tarantula Pro Joystick Cover Replacement, Joystick Covers: step 1, image 1 of 3 GameSir Tarantula Pro Joystick Cover Replacement, Joystick Covers: step 1, image 2 of 3 GameSir Tarantula Pro Joystick Cover Replacement, Joystick Covers: step 1, image 3 of 3
      • Use the tip of a spudger to remove the rubber screw covers from the backs of the handles and the top edge of the back case.
      • Gently pry up each screw cover and lift it out.
      Ask FixBot
    2. GameSir Tarantula Pro Joystick Cover Replacement: step 2, image 1 of 2 GameSir Tarantula Pro Joystick Cover Replacement: step 2, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the 4.0 mm screws from the back case.
      • Because the screws are deeply recessed, use a long, thin driver to remove them.
      Ask FixBot
    3. GameSir Tarantula Pro Joystick Cover Replacement: step 3, image 1 of 2 GameSir Tarantula Pro Joystick Cover Replacement: step 3, image 2 of 2
      • Slide a spudger around the seam between the top and bottom cases to release the retaining clips.
      • Remove the bottom case.
      Ask FixBot
    4. GameSir Tarantula Pro Joystick Cover Replacement: step 4, image 1 of 3 GameSir Tarantula Pro Joystick Cover Replacement: step 4, image 2 of 3 GameSir Tarantula Pro Joystick Cover Replacement: step 4, image 3 of 3
      • Use the Phillips #000 screwdriver to remove the nine 4.0 mm screws from the motherboard.
      Ask FixBot
    5. GameSir Tarantula Pro Joystick Cover Replacement: step 5, image 1 of 3 GameSir Tarantula Pro Joystick Cover Replacement: step 5, image 2 of 3 GameSir Tarantula Pro Joystick Cover Replacement: step 5, image 3 of 3
      • Use the point of a spudger to push on alternating sides of each JST connector to "walk" it out of its socket.
      • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
      • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
      • If you're having trouble, try rocking the connector side-to-side to loosen it.
      • If the connector's socket has cutouts, you can insert the arms of a pair of sharp tweezers into the cutouts and gently push the connector out of its socket.
      • Carefully remove the battery from the controller.
      • Avoid bending or puncturing the battery.
      • The battery is secured by double-sided tape, so it may take some work to loosen the adhesive before you can completely remove the battery. Use the iFixit adhesive remover if you have trouble removing the battery.
      Ask FixBot
    6. GameSir Tarantula Pro Joystick Cover Replacement: step 6, image 1 of 2 GameSir Tarantula Pro Joystick Cover Replacement: step 6, image 2 of 2
      • Carefully remove the motherboard from the shell.
      • Flip the motherboard over so the joysticks are facing upward.
      Ask FixBot
    7. GameSir Tarantula Pro Joystick Cover Replacement: step 7, image 1 of 3 GameSir Tarantula Pro Joystick Cover Replacement: step 7, image 2 of 3 GameSir Tarantula Pro Joystick Cover Replacement: step 7, image 3 of 3
      • Remove the joysticks by gently pulling them up and off their mounts.
      • When installing the new joystick covers, press them down onto the joysticks until you hear a click, indicating they are securely locked in place.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Eduardo Pereira
195 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 20
Past 7 Days: 96
Past 30 Days: 393
All Time: 709
