Up to 20% off select tools
How to Use iFixit Adhesive Remover
Views: 45K
View statistics:
Past 24 Hours:
20
Past 7 Days:
181
Past 30 Days:
813
All Time:
45,316
Comments: 16
1 comment on steps, 15 guide comments.
Go to guide comments
Completed: 64
64 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Parts
Introduction
Go to step 1 ↓
You can remove glued-down components in all kinds of ways. One of the simplest is to use a solvent, such as iFixit Adhesive Remover, to dissolve the glue. Follow this guide for general tips and instructions for using adhesive remover on any device.
    1. How to Use iFixit Adhesive Remover, How to Use iFixit Adhesive Remover: step 1, image 1 of 3 How to Use iFixit Adhesive Remover, How to Use iFixit Adhesive Remover: step 1, image 2 of 3 How to Use iFixit Adhesive Remover, How to Use iFixit Adhesive Remover: step 1, image 3 of 3
      • First, prepare your device for surgery.
      • Always disconnect the battery before you start.
      • Cover or remove any components that may be vulnerable to damage, in case the solvent drips or leaks somewhere it shouldn't. (A sheet of aluminum foil offers good protection.)
      • Vulnerable components include display coatings and plastic parts such as speaker housings and keyboard keys.
      • If necessary, direct the flow of solvent away from sensitive components by elevating one side of your device.
      • If contact with sensitive components can't be avoided, use a milder solvent such as 99% isopropyl alcohol. It will take longer and require more care, but alcohol alone won't damage most electronic components.
      Ask FixBot
    2. How to Use iFixit Adhesive Remover: step 2, image 1 of 2 How to Use iFixit Adhesive Remover: step 2, image 2 of 2
      • Now that your device is prepped, it's time to prep yourself.
      • iFixit adhesive remover contains acetone, a serious eye irritant and a mild skin irritant. Read all cautions on the adhesive remover label.
      • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
      • Do not wear contact lenses without eye protection.
      • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
      Ask FixBot
    3. How to Use iFixit Adhesive Remover: step 3, image 1 of 3 How to Use iFixit Adhesive Remover: step 3, image 2 of 3 How to Use iFixit Adhesive Remover: step 3, image 3 of 3
      • The adhesive remover bottle was updated in some regions. If yours doesn't have a black rubber stopper, you only need to unscrew the tip and remove the paper seal. Skip the remainder of this step.
      • Pull off the black rubber stopper from your bottle of adhesive remover.
      • Twist to loosen or remove the bottle cap before you cut the applicator tip.
      • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
      • Use scissors to cut off the sealed tip of the applicator.
      • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
      • Twist and close the bottle cap securely before you proceed further.
      Ask FixBot
    4. How to Use iFixit Adhesive Remover: step 4, image 1 of 2 How to Use iFixit Adhesive Remover: step 4, image 2 of 2
      • Apply a few drops of adhesive remover evenly along the elevated edge of your glued-down component.
      • A little bit goes a long way, so start with a very small amount. You can always add more later if needed. Applying the solvent in small amounts helps prevent unwanted leaks.
      • Wait 2-3 minutes for the liquid adhesive remover to penetrate and soften the adhesive before you proceed to the next step.
      Ask FixBot
    5. How to Use iFixit Adhesive Remover: step 5, image 1 of 3 How to Use iFixit Adhesive Remover: step 5, image 2 of 3 How to Use iFixit Adhesive Remover: step 5, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Gently slide a plastic card or other thin pry tool under the adhered component.
      • It may help to gently wiggle or twist the card as you go. If you're separating a battery, be careful not to deform or puncture it.
      • If you're struggling, apply a few more drops of adhesive remover and wait about a minute before trying again.
      • If your device has an especially tight fit and you have trouble inserting a tool, try working a piece of floss or wire underneath the component, and pull it side-to-side in a sawing motion to separate the adhesive.
      • Lift and separate your newly-unglued component.
      Ask FixBot
    6. How to Use iFixit Adhesive Remover: step 6, image 1 of 3 How to Use iFixit Adhesive Remover: step 6, image 2 of 3 How to Use iFixit Adhesive Remover: step 6, image 3 of 3
      Buy
      • Before installing or gluing down any new components, remove any remaining adhesive residue from your device.
      • Peel off larger pieces of adhesive using tweezers or gloved fingers.
      • Scrape away any remaining adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction, not back and forth, until all the adhesive residue is gone.
      • This can take quite a bit of work, so be patient.
      • When your device is clean and dry, go ahead and install your new part and reassemble your device.
      Ask FixBot
Nice work! If you have any leftover adhesive remover, you can save it for your next project.
64 other people completed this guide.
Author
with
Jeff Suovanen
455,892 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
15 Guide Comments
Can I use adhesive remover on glued down flex cables? Like the cable for the Touch ID button on the iPhone 7 Plus. Or will this damage the cable? How about isopropyl alcohol based adhesive remover?
havarh - Reply Share
Mild heat and/or a little isopropyl alcohol should do the trick. You don’t need to risk using anything more aggressive than that.
Jeff Suovanen - Reply Share
Can I used this to pop open my iPhone 8 Plus?
Tech Savvy Jan - Reply Share
can i use this to remove thermal adhesive from a s70 adata ssd, the dram modules are glue directly to the heatsink
podermexico - Reply Share
This will not be an ideal or guaranteed solution, but it may be feasible depending on the type and condition of the adhesive used. For this application, I would strongly recommend using isopropyl alcohol, preferably at a concentration of 99.9%. It is significantly safer for electronic components and PCB materials, and in many cases sufficient to soften or remove residual thermal adhesive without risking damage to surrounding components.
Tom - Reply Share
Past 24 Hours: 20
Past 7 Days: 181
Past 30 Days: 813
All Time: 45,316
