Galaxy S23 Ultra Screen Replacement
    1. Galaxy S23 Ultra Screen Replacement, Safety precautions: step 1, image 1 of 1
      • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone and completely power it down.
      Ask FixBot
    1. Galaxy S23 Ultra Screen Replacement, Heat the right edge: step 2, image 1 of 1
      • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
      Ask FixBot
    2. Galaxy S23 Ultra Screen Replacement, Adhesive information: step 3, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Adhesive information: step 3, image 2 of 2
      • While you wait for the adhesive to soften, note the following:
      • There's adhesive securing the back cover around the perimeter of the frame.
      • The adhesive is strongest in the bottom right and top left corners.
      Ask FixBot
    3. Galaxy S23 Ultra Screen Replacement, Insert an opening pick: step 4, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Insert an opening pick: step 4, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Insert an opening pick: step 4, image 3 of 3
      • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
      • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap.
      Ask FixBot
    4. Galaxy S23 Ultra Screen Replacement, Separate the right adhesive: step 5, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Separate the right adhesive: step 5, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Separate the right adhesive: step 5, image 3 of 3
      • Slide the pick back and forth along the right edge to separate the adhesive.
      • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Galaxy S23 Ultra Screen Replacement, Heat the bottom edge: step 6, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
      Ask FixBot
    6. Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: step 7, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: step 7, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: step 7, image 3 of 3
      • Insert a second opening pick at the bottom right corner.
      • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
      • Be careful while working around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
      Ask FixBot
    7. Galaxy S23 Ultra Screen Replacement, Separate the bottom adhesive: step 8, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Separate the bottom adhesive: step 8, image 2 of 2
      • Slide your opening pick to the bottom left corner to separate the adhesive.
      • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    8. Galaxy S23 Ultra Screen Replacement, Heat the left edge: step 9, image 1 of 1
      • Apply a heated iOpener to the left edge of the back cover for two minutes.
      Ask FixBot
    9. Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: step 10, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: step 10, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: step 10, image 3 of 3
      • Insert a third opening pick at the bottom left corner.
      • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
      Ask FixBot
    10. Galaxy S23 Ultra Screen Replacement, Separate the left adhesive: step 11, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Separate the left adhesive: step 11, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Separate the left adhesive: step 11, image 3 of 3
      • Slide your opening pick along the left edge to separate the adhesive, stopping when you reach the power button.
      • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
      • Leave the pick in the left edge to prevent the adhesive from resealing.
      Ask FixBot
    11. Galaxy S23 Ultra Screen Replacement, Heat the top edge: step 12, image 1 of 1
      • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
      Ask FixBot
    12. Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: step 13, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: step 13, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: step 13, image 3 of 3
      • Insert an opening pick in the gap at the top right edge.
      • Angle the pick upward to match the curved edge and rotate it around the top right corner.
      Ask FixBot
    13. Galaxy S23 Ultra Screen Replacement, Separate the top adhesive: step 14, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Separate the top adhesive: step 14, image 2 of 2
      • Slide the pick to the top left corner to separate the adhesive.
      • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
      • Leave the pick in to prevent the adhesive from resealing.
      Ask FixBot
    14. Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: step 15, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: step 15, image 2 of 2
      • Insert an opening pick in the gap at the top left edge.
      • Only insert the pick up to 4 mm, as you may damage the cameras.
      • Angle the pick upward to match the curved edge and rotate it around the top left corner.
      Ask FixBot
    15. Galaxy S23 Ultra Screen Replacement, Separate the remaining adhesive: step 16, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Separate the remaining adhesive: step 16, image 2 of 2
      • Slide the pick toward the bottom camera to separate through the remaining adhesive, stopping before you reach the power button.
      Ask FixBot
    16. Galaxy S23 Ultra Screen Replacement, Remove the back cover: step 17, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Remove the back cover: step 17, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Remove the back cover: step 17, image 3 of 3
      • Grab and remove the back cover.
      • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
    1. Galaxy S23 Ultra Screen Replacement, Disconnect the NFC antenna and charging coil: step 18, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Disconnect the NFC antenna and charging coil: step 18, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Disconnect the NFC antenna and charging coil: step 18, image 3 of 3
      • Use the pointed end of a spudger to pry up and disconnect the NFC antenna press connector from the motherboard.
      • Repeat for the wireless charging coil press connector.
      • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    2. Galaxy S23 Ultra Screen Replacement, Separate the coil adhesive: step 19, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Separate the coil adhesive: step 19, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Separate the coil adhesive: step 19, image 3 of 3
      • The wireless charging coil is lightly adhered to the battery.
      • Insert an opening pick between the right edge of the wireless charging coil and the battery.
      • Slide the pick along the right edge to separate the adhesive.
      Ask FixBot
    3. Galaxy S23 Ultra Screen Replacement, Unfasten the NFC antenna and charging coil: step 20, image 1 of 1
      • Use a Phillips screwdriver to remove the five 3.5 mm-long screws securing the NFC antenna and charging coil.
      Ask FixBot
    4. Galaxy S23 Ultra Screen Replacement: step 21, image 1 of 2 Galaxy S23 Ultra Screen Replacement: step 21, image 2 of 2
      • Insert an opening pick between the top edge of the wireless charging coil and the frame.
      • Slide the pick toward the right edge to separate the remaining adhesive.
      Ask FixBot
    5. Galaxy S23 Ultra Screen Replacement, Unfasten the loudspeaker: step 22, image 1 of 1
      • Use a Phillips screwdriver to remove the six 3.5 mm screws securing the loudspeaker.
      Ask FixBot
    6. Galaxy S23 Ultra Screen Replacement, Unclip the loudspeaker: step 23, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Unclip the loudspeaker: step 23, image 2 of 2
      • Insert the pointed end of your spudger between the upper right corner of the loudspeaker and the frame.
      • Pry up to unclip the loudspeaker from the frame.
      • Don't pry against the battery. Use protrusions in the frame for leverage.
      • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
      Ask FixBot
    7. Galaxy S23 Ultra Screen Replacement, Remove the charging coil and loudspeaker assembly: step 24, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Remove the charging coil and loudspeaker assembly: step 24, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Remove the charging coil and loudspeaker assembly: step 24, image 3 of 3
      • Grab and remove the NFC, wireless charging coil, and loudspeaker from the frame.
      Ask FixBot
    1. Galaxy S23 Ultra Screen Replacement, Disconnect the battery: step 25, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Disconnect the battery: step 25, image 2 of 2
      • Use your spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    1. Galaxy S23 Ultra Screen Replacement, Disconnect the interconnect cables: step 26, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Disconnect the interconnect cables: step 26, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Disconnect the interconnect cables: step 26, image 3 of 3
      • Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the motherboard.
      • Repeat for the primary interconnect cable.
      Ask FixBot
    2. Galaxy S23 Ultra Screen Replacement: step 27, image 1 of 3 Galaxy S23 Ultra Screen Replacement: step 27, image 2 of 3 Galaxy S23 Ultra Screen Replacement: step 27, image 3 of 3
      • Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the charging board.
      Ask FixBot
    3. Galaxy S23 Ultra Screen Replacement, Remove the interconnect cables: step 28, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Remove the interconnect cables: step 28, image 2 of 2
      • Grab and remove the interconnect cables from the frame.
      Ask FixBot
    1. Galaxy S23 Ultra Screen Replacement, Disconnect the earpiece speaker: step 29, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Disconnect the earpiece speaker: step 29, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the earpiece speaker press connector.
      Ask FixBot
    2. Galaxy S23 Ultra Screen Replacement, Unfasten the motherboard cover: step 30, image 1 of 1
      • Use a Phillips screwdriver to remove the five 3.5 mm-long screws securing the motherboard cover.
      Ask FixBot
    3. Galaxy S23 Ultra Screen Replacement, Remove the motherboard cover: step 31, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Remove the motherboard cover: step 31, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Remove the motherboard cover: step 31, image 3 of 3
      • Insert the point of your spudger between the bottom right corner of the motherboard cover and the frame.
      • Pry up on the cover to unclip it from the frame.
      • Remove the motherboard cover.
      • During reassembly, press down on the cover to secure its clips to the frame.
      Ask FixBot
    1. Galaxy S23 Ultra Screen Replacement, Disconnect the front-facing camera: step 32, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Disconnect the front-facing camera: step 32, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the front-facing camera press connector.
      Ask FixBot
    2. Galaxy S23 Ultra Screen Replacement, Disconnect the fingerprint reader: step 33, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Disconnect the fingerprint reader: step 33, image 2 of 2
      • Use your spudger to pry up and disconnect the fingerprint reader press connector.
      Ask FixBot
    3. Galaxy S23 Ultra Screen Replacement, Disconnect the screen: step 34, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Disconnect the screen: step 34, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the screen press connector from the motherboard.
      Ask FixBot
    4. Galaxy S23 Ultra Screen Replacement: step 35, image 1 of 2 Galaxy S23 Ultra Screen Replacement: step 35, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the screen press connector from the display cutout near the bottom of the phone.
      Ask FixBot
    5. Galaxy S23 Ultra Screen Replacement, Remove the screen cable: step 36, image 1 of 1
      • Grab and remove the screen cable from the frame.
      Ask FixBot
    6. Galaxy S23 Ultra Screen Replacement, Disconnect the right 5G mmWave antenna: step 37, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Disconnect the right 5G mmWave antenna: step 37, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the right 5G mmWave antenna press connector.
      Ask FixBot
    7. Galaxy S23 Ultra Screen Replacement, Disconnect the stylus: step 38, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Disconnect the stylus: step 38, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the stylus press connector.
      Ask FixBot
    8. Galaxy S23 Ultra Screen Replacement, Disconnect the left 5G mmWave antenna: step 39, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Disconnect the left 5G mmWave antenna: step 39, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the left 5G mmWave antenna press connector.
      Ask FixBot
    9. Galaxy S23 Ultra Screen Replacement, Unfasten the motherboard: step 40, image 1 of 1
      • Use your Phillips screwdriver to remove the single 4 mm-long screw securing the motherboard.
      Ask FixBot
    10. Galaxy S23 Ultra Screen Replacement, Remove the motherboard: step 41, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Remove the motherboard: step 41, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Remove the motherboard: step 41, image 3 of 3
      • Insert the point of your spudger between the top left of the motherboard and the frame.
      • Pry the motherboard up until you can grab it with your fingers.
      • Grab the motherboard and remove it from the frame.
      • Be careful not to snag any loose cables.
      • During reassembly, make sure the cables are above the motherboard when reinserting it.
      Ask FixBot
    1. Galaxy S23 Ultra Screen Replacement, Put the back cover on: step 42, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Put the back cover on: step 42, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Put the back cover on: step 42, image 3 of 3
      • Place the back cover back on the frame to protect the battery and your phone's internals from damage.
      • Flip your phone over so the screen is facing up.
      Ask FixBot
    2. Galaxy S23 Ultra Screen Replacement, Heat the screen's top edge: step 43, image 1 of 1
      • Use a hair dryer or heat gun to heat the top edge of the screen just until it's hot to the touch.
      • Be careful not to heat the phone any hotter than this—the battery is susceptible to heat damage.
      Ask FixBot
    3. Galaxy S23 Ultra Screen Replacement: step 44, image 1 of 1
      • If your screen is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the top edge big enough for a suction cup to stick to.
      Ask FixBot
    4. Galaxy S23 Ultra Screen Replacement, Apply a suction handle: step 45, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Apply a suction handle: step 45, image 2 of 2
      • Apply a suction handle to the center of the screen's top edge, as close to the edge as possible.
      Ask FixBot
    5. Galaxy S23 Ultra Screen Replacement, Tool and safety information: step 46, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Tool and safety information: step 46, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Tool and safety information: step 46, image 3 of 3
      Tool used on this step:
      iFlex Opening Tool
      $11.99
      Buy
      • The gap between the front glass and frame is extremely small. You'll need a thin, rigid tool such as an iFlex to create the initial gap.
      • The display panel and display glass will remove separately—although destructive, this is the best method. The display glass will usually lift away from the strongly-adhered panel first.
      • Take the following safety precautions while removing the front glass during the next few steps:
      • Don't grip the iFlex or similar metal tools by the edges—they're very sharp.
      • The front glass can shatter and throw shards of glass around your workspace. Consider wearing gloves and safety glasses to protect yourself.
      Ask FixBot
    6. Galaxy S23 Ultra Screen Replacement, Insert an iFlex: step 47, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Insert an iFlex: step 47, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Insert an iFlex: step 47, image 3 of 3
      • Insert the iFlex at a downward angle into the earpiece speaker gap between the top edge of the front glass and frame.
      Ask FixBot
    7. Galaxy S23 Ultra Screen Replacement: step 48, image 1 of 2 Galaxy S23 Ultra Screen Replacement: step 48, image 2 of 2
      • Lift the suction handle with strong, steady force and lower the iFlex so it slides under the front glass, between the glass and the display panel. A large portion of the front glass may separate—that's fine. You may see the tip of the iFlex under the glass.
      • The iFlex only needs to be inserted just enough to separate the front glass and create an initial gap. If inserted too far, it may damage the front-facing camera.
      Ask FixBot
    8. Galaxy S23 Ultra Screen Replacement, Replace the iFlex with an opening pick: step 49, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Replace the iFlex with an opening pick: step 49, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Replace the iFlex with an opening pick: step 49, image 3 of 3
      • Insert the tip of an opening pick under the front glass and remove the iFlex.
      Ask FixBot
    9. Galaxy S23 Ultra Screen Replacement, Separate the front glass: step 50, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Separate the front glass: step 50, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Separate the front glass: step 50, image 3 of 3
      • Slide the opening pick around the perimeter of the back glass to separate the adhesive securing it to the display panel.
      • If you're having trouble, use a hair dryer or heat gun to heat the edges.
      Ask FixBot
    10. Galaxy S23 Ultra Screen Replacement: step 51, image 1 of 2 Galaxy S23 Ultra Screen Replacement: step 51, image 2 of 2
      • Lift and remove the front glass.
      Ask FixBot
    11. Galaxy S23 Ultra Screen Replacement, Separate the display panel: step 52, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Separate the display panel: step 52, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Separate the display panel: step 52, image 3 of 3
      • Slide an opening pick under the bottom corner of the display panel and lift to separate the adhesive.
      • This adhesive is very strong. If you're having trouble separating it, use a hair dryer or heat gun to heat the display panel and soften the adhesive.
      Ask FixBot
    12. Galaxy S23 Ultra Screen Replacement: step 53, image 1 of 3 Galaxy S23 Ultra Screen Replacement: step 53, image 2 of 3 Galaxy S23 Ultra Screen Replacement: step 53, image 3 of 3
      • Continue sliding your opening pick under the perimeter of the display panel to separate the remaining adhesive.
      Ask FixBot
    13. Galaxy S23 Ultra Screen Replacement, Remove the display panel: step 54, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Remove the display panel: step 54, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Remove the display panel: step 54, image 3 of 3
      • Slowly peel up the display panel, making sure you thread the cable near the top left corner through its cutout in the frame.
      • If you're having trouble, go back around the perimeter of the screen with an opening pick and separate any adhesive you may have missed.
      Ask FixBot
    14. Galaxy S23 Ultra Screen Replacement: step 55, image 1 of 1
      • You're left with the screen panel and front glass.
      Ask FixBot
    15. Galaxy S23 Ultra Screen Replacement, Remove all of the old screen adhesive: step 56, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Remove all of the old screen adhesive: step 56, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Remove all of the old screen adhesive: step 56, image 3 of 3
      • Check the bottom half of the frame for pieces of thin plastic left behind by the screen.
      • Use a spudger and tweezers to scrape up and remove the plastic.
      Ask FixBot
    16. Galaxy S23 Ultra Screen Replacement: step 57, image 1 of 3 Galaxy S23 Ultra Screen Replacement: step 57, image 2 of 3 Galaxy S23 Ultra Screen Replacement: step 57, image 3 of 3
      • In order for your new screen to adhere properly, you'll need to thoroughly remove all of the old screen adhesive and its residue.
      • Use a spudger to scrape up and remove all of the old screen adhesive from the perimeter of the frame.
      • Once all of the old adhesive is removed, use high concentration (>90%) isopropyl alcohol and a microfiber cloth to remove any remaining adhesive residue.
      • Allow the alcohol to dry completely before continuing.
      Ask FixBot
    17. Galaxy S23 Ultra Screen Replacement, Apply the main adhesive: step 58, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Apply the main adhesive: step 58, image 2 of 2
      • Before applying the larger piece of replacement adhesive, it's helpful to see how it will be oriented.
      • There's a second, smaller piece of adhesive that'll be applied later on.
      • Hold the adhesive so the clear liner is on the bottom and test-fit it against the frame to find the proper orientation.
      Ask FixBot
    18. Galaxy S23 Ultra Screen Replacement: step 59, image 1 of 1
      • Peel down the top half of the larger, clear liner to expose the adhesive—don't remove the whole liner yet.
      Ask FixBot
    19. Galaxy S23 Ultra Screen Replacement: step 60, image 1 of 3 Galaxy S23 Ultra Screen Replacement: step 60, image 2 of 3 Galaxy S23 Ultra Screen Replacement: step 60, image 3 of 3
      • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after it's applied.
      • Keep the larger, clear liner folded towards the bottom of the phone during this step.
      • Carefully place the top edge of the adhesive onto the frame.
      • Once the top edge is aligned and applied, slowly lay the rest of the adhesive onto the frame, peeling the clear liner down and away as you go.
      Ask FixBot
    20. Galaxy S23 Ultra Screen Replacement: step 61, image 1 of 3 Galaxy S23 Ultra Screen Replacement: step 61, image 2 of 3 Galaxy S23 Ultra Screen Replacement: step 61, image 3 of 3
      • Use your fingers to firmly press the adhesive into place on the frame.
      • Use the flat end of a spudger to further secure the adhesive.
      Ask FixBot
    21. Galaxy S23 Ultra Screen Replacement, Apply the smaller piece of adhesive: step 62, image 1 of 2 Galaxy S23 Ultra Screen Replacement, Apply the smaller piece of adhesive: step 62, image 2 of 2
      • Peel off the larger, more rigid clear‑liner on the second piece of adhesive.
      • With the adhesive's remaining liners facing up, carefully lay the adhesive into place along the bottom edge of the frame.
      Ask FixBot
    22. Galaxy S23 Ultra Screen Replacement: step 63, image 1 of 2 Galaxy S23 Ultra Screen Replacement: step 63, image 2 of 2
      • Use the point of a spudger to firmly press along the entire piece of adhesive to secure it to the frame.
      Ask FixBot
    23. Galaxy S23 Ultra Screen Replacement, Remove the liners: step 64, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Remove the liners: step 64, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Remove the liners: step 64, image 3 of 3
      • Remove the two remaining liners (one clear, one green) from the small, bottom‑edge adhesive.
      • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
      Ask FixBot
    24. Galaxy S23 Ultra Screen Replacement: step 65, image 1 of 3 Galaxy S23 Ultra Screen Replacement: step 65, image 2 of 3 Galaxy S23 Ultra Screen Replacement: step 65, image 3 of 3
      • Use the pull tab in the top right corner to peel and remove the remaining liner from the main adhesive.
      Ask FixBot
    25. Galaxy S23 Ultra Screen Replacement, Secure the new screen: step 66, image 1 of 3 Galaxy S23 Ultra Screen Replacement, Secure the new screen: step 66, image 2 of 3 Galaxy S23 Ultra Screen Replacement, Secure the new screen: step 66, image 3 of 3
      • Carefully check the underside of your replacement screen for any liners or tabs and remove them.
      • Thread the screen cable through its cutout near the top left corner of the frame and lay the screen into place.
      • Press firmly around the perimeter of the screen to secure it.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order starting with this step.
24 other people completed this guide.
Spencer Day
206,396 Reputation
1,268 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
6 Guide Comments
where the hell is the screen for purchase, dingus?
JustaRoan - Reply Share
🤣🤣🤣🤣🤣🤣🤣 Good point. I would not deal with this though. Not worth 250$ +tx for samsung to do it, or trade in on next phone
David Kaleky - Reply Share
reparieren lohnt sich gar nicht das kaputte Handy kostet sagen wir roundabout 250 dann kostet das kaputte Display mit den kleben und so 300 irgendwas also sagen wir sind wir bei 500 wenn ich jetzt einen referbisch-gerät kaufe kostet das auch an die 500 und ich habe keine Arbeitszeit reingesteckt also ich dachte man würde dabei billiger wegkommen beim Reparieren aber anscheinend nicht
Dennis Witt - Reply Share
Ich habe das gerade durchgeführt. Hat perfekt geklappt. Einziger Hinweis: Ich würde von vornherein ein neues Backcover mit einplanen. Ausserdem würde ich es NICHT 'zum Schutz der Innereien' an der entsprechenden Stelle der Anleitung wieder darauflegen. Denn danach ist es wieder fest angeklebt und man muss es noch einmal abhebeln.
Danke für die Anleitung.
Thomas - Reply Share
Awesome Thank you! seems like a fun challenge, and I accept. I just picked up my Ifixit Pro tech toolkit today, and now im ordering my replacement screen. I really appreciate you guy making this guide!
stan sams - Reply Share
Past 24 Hours: 138
Past 7 Days: 885
Past 30 Days: 3,946
All Time: 94,403
