Fujifilm Instax 210 Disassembly
Views: 4.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
144
All Time:
4,500
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
This will guide you how to open the back and front casing. You will be able to access most of the electronics, the flash, viewfinder and the conveyor mechanism. You will need a Philips screwdriver size 0 or 00 and flat head srewdriver.
Tools
    1. Fujifilm Instax 210 Disassembly, Camera: step 1, image 1 of 1
      • Open the battery compartment, remove the batteries and remove the two Philips screws
      • Remove the film casette from the film compartment.
      Ask FixBot
    2. Fujifilm Instax 210 Disassembly: step 2, image 1 of 1
      • Remove the two Philips screws on the back.
      Ask FixBot
    3. Fujifilm Instax 210 Disassembly: step 3, image 1 of 1
      • Remove the panel of the controls on the side. Start on the bottom. It is just sticked in with tape
      Ask FixBot
    4. Fujifilm Instax 210 Disassembly: step 4, image 1 of 1
      • Gently pull the back cover while poking into the two holes on the bottom of the film compartment. Previously removed screws are also sufficient for this task.
      Ask FixBot
    5. Fujifilm Instax 210 Disassembly: step 5, image 1 of 1
      • To remove the front cover lift the clips highlighted in this picture. The right one is hidden behind the wires.
      Ask FixBot
    6. Fujifilm Instax 210 Disassembly: step 6, image 1 of 1
      • Congratulations. You did it. Safety Note: The black cylinder under the flash that looks like a battery is the flash capacitor. Ensure that it is discharged before you start tampering with the electronics.
      • Charged capacitors can pose an electrocution danger. Be sure to discharge the capacitor before you begin working on the device.
      • To discharge the capacitor shorten the two highlighted solder joints between the flash and capacitor with a big screwdriver or a paper clip. Make sure you do not touch any electronic parts except the two joints.
      Ask FixBot
Florian Diwald
133 Reputation
1 Guide authored
2 Guide Comments
I have a question can I pm about a instax 210? Or possible to tell me where I can inquire?
Ian Bonnardel (IBwhiteguy) - Reply Share
Sure. I made a google form: https://forms.gle/QvE9LDxi7AHpvCZA6
(don't want to make my E-Mail address public)
Florian Diwald - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 144
All Time: 4,500
