Up to 20% off select tools
DualShock 3 Trigger Buttons Replacement
Views: 146K
View statistics:
Past 24 Hours:
35
Past 7 Days:
262
Past 30 Days:
1,171
All Time:
146,020
Comments: 28
19 comments on steps, 9 guide comments.
Go to guide comments
Completed: 79
79 people have marked this guide "completed." Will you be next?
Favorites: 65
65 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the plastic trigger buttons. The #2 trigger button has an attached internal spring.
    1. DualShock 3 Trigger Buttons Replacement, Rear Cover: step 1, image 1 of 1
      • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
      Ask FixBot
    2. DualShock 3 Trigger Buttons Replacement: step 2, image 1 of 1
      • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
      Ask FixBot
    3. DualShock 3 Trigger Buttons Replacement: step 3, image 1 of 2 DualShock 3 Trigger Buttons Replacement: step 3, image 2 of 2
      • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
      • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
      • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
      Ask FixBot
    1. DualShock 3 Trigger Buttons Replacement, Trigger Buttons: step 4, image 1 of 1
      • While holding the black plastic trigger retainer with one hand, pull the #2 trigger off of its axle.
      Ask FixBot
    2. DualShock 3 Trigger Buttons Replacement: step 5, image 1 of 2 DualShock 3 Trigger Buttons Replacement: step 5, image 2 of 2
      • When reinstalling the #2 trigger, be sure the spring is positioned as shown before popping the axle back into place.
      Ask FixBot
    3. DualShock 3 Trigger Buttons Replacement: step 6, image 1 of 2 DualShock 3 Trigger Buttons Replacement: step 6, image 2 of 2
      • Pull the black plastic trigger retainer slightly away from the front cover.
      • Pull the #1 button out of the front cover.
      Ask FixBot
    4. DualShock 3 Trigger Buttons Replacement: step 7, image 1 of 2 DualShock 3 Trigger Buttons Replacement: step 7, image 2 of 2
      • Before sliding the trigger button retainer back into the rails molded into the front cover, be sure that the cylindrical post attached to the #1 button is sitting flat on the green rubber electronic switch cover. Failure to do so may lead to problems with fit during reassembly, and may cause the controller to not recognize inputs from the #1 button during operation.
      • The trigger button assembly is properly installed when the lip on the trigger button retainer sits flat against the motherboard.
      Ask FixBot
79 other people completed this guide.
Author
with
9 Guide Comments
Might want to add that there's a small catch/tab in the middle of the bottom of the controller that needs to be released when taking apart the covers.
This worked great, and also works on normal Sixaxis controllers. I used this to swap the broken spring from the L2 button on my DS3 for a good spring from my Sixaxis. Works like new now.
Will Foss - Reply Share
The little green eletronic ribben where is it supposed to go?
dmall - Reply Share
The #00 screwdriver is working better
Leopold287 - Reply Share
Did you replace button 2 rod with plastic replacement part or use original rod piece when fixing button 2
Sidney Klemkosky - Reply Share
Is there a way I can buy trigger retainers?
CynicalSheep - Reply Share
Past 24 Hours: 35
Past 7 Days: 262
Past 30 Days: 1,171
All Time: 146,020
