Up to 20% off select tools
DualShock 3 Buttons Replacement
Views: 176K
View statistics:
Past 24 Hours:
16
Past 7 Days:
158
Past 30 Days:
662
All Time:
176,016
Comments: 36
30 comments on steps, 6 guide comments.
Go to guide comments
Completed: 111
111 people have marked this guide "completed." Will you be next?
Favorites: 79
79 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the plastic button covers and the rubber button contacts on any DualShock 3 controller.
    1. DualShock 3 Buttons Replacement, Rear Cover: step 1, image 1 of 1
      • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
      Ask FixBot
    2. DualShock 3 Buttons Replacement: step 2, image 1 of 1
      • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
      Ask FixBot
    3. DualShock 3 Buttons Replacement: step 3, image 1 of 2 DualShock 3 Buttons Replacement: step 3, image 2 of 2
      • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
      • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
      • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
      Ask FixBot
    1. DualShock 3 Buttons Replacement, Battery: step 4, image 1 of 1
      • Lift the battery off the motherboard for enough clearance to access the battery connector.
      Ask FixBot
    2. DualShock 3 Buttons Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Carefully pull the battery connector away from its socket on the motherboard.
      • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
      Ask FixBot
    1. DualShock 3 Buttons Replacement, Motherboard Assembly: step 6, image 1 of 1
      • Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
      Ask FixBot
    2. DualShock 3 Buttons Replacement: step 7, image 1 of 3 DualShock 3 Buttons Replacement: step 7, image 2 of 3 DualShock 3 Buttons Replacement: step 7, image 3 of 3
      • Slide the trigger button retainers slightly away from the front cover.
      • Remove the #1 button on both sides.
      Ask FixBot
    3. DualShock 3 Buttons Replacement: step 8, image 1 of 2 DualShock 3 Buttons Replacement: step 8, image 2 of 2
      • Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
      Ask FixBot
    4. DualShock 3 Buttons Replacement: step 9, image 1 of 1
      • Remove the motherboard assembly from the front cover.
      • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
      Ask FixBot
    1. DualShock 3 Buttons Replacement, Buttons: step 10, image 1 of 2 DualShock 3 Buttons Replacement, Buttons: step 10, image 2 of 2
      • Lift the rubber button contacts off the front controller cover to access the plastic button covers.
      • Lift any damaged plastic button covers out of the controller cover.
      Ask FixBot
    2. DualShock 3 Buttons Replacement: step 11, image 1 of 1
      • The D-pad has a three-armed plastic piece that must be installed as shown before installing the rubber button pad for it to work properly.
      Ask FixBot
111 other people completed this guide.
Author
with
6 Guide Comments
My Dualshock 3 didn't have the three armed plastic piece on the D-pad. Mine's a red one, relatively recent. My controller also had the problem where it would randomly send button press events when using the L-stick. I traced the problem to the ribbon connector between the board and the contacts, which was very dirty. I cleaned the contacts and put the controller back together with an additional rubber shim between the back cover and the battery, which got rid of the creakiness of the somewhat loose-fitting case. Works great now.
Kevin - Reply Share
How do you clean the contacts? Is there a special way?
yeshuabendavid - Reply Share
Thanks. ^^ Tightened screws after opening it and this kind of problem got solved.
Janne K - Reply Share
Are these instructions the same for the dual-shock 2?
Larry Howard - Reply Share
TNX-could not really figure out where the 3-armed plastic should fit in but tnx to step 11 i know-now im going to dismantle my controller again.
Kristian Brandström - Reply Share
Past 24 Hours: 16
Past 7 Days: 158
Past 30 Days: 662
All Time: 176,016
