Up to 20% off select tools
Door Mirror Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
30
Past 30 Days:
136
All Time:
1,739
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide will walk you through on the steps on replacing your door mirror. You will need to be careful with handling the mirror, as it could potentially shattered if not handled properly. The tools that you will need for this is just screwdriver, but a power drill can also be used.
    1. Door Mirror Replacement, Door Mirror: step 1, image 1 of 1
      • Use a screwdriver to remove the two brackets securing the top of the mirror.
      • The mirror will fall forward once the two top brackets are released; be sure to support the mirror as you unscrew the brackets.
      • The type of screwdriver needed will depend on your specific brackets.
      Ask FixBot
    2. Door Mirror Replacement: step 2, image 1 of 1
      • Lift the broken mirror off of the door.
      • Remove any cardboard or other cushioning (if any) from the door.
      Ask FixBot
    3. Door Mirror Replacement: step 3, image 1 of 1
      • Loosen, but don't remove, the bottom brackets to accommodate the width of the new mirror.
      Ask FixBot
    4. Door Mirror Replacement: step 4, image 1 of 1
      • If you have new mirror supports, then remove the old brackets entirely and replace them with the new brackets.
      Ask FixBot
    5. Door Mirror Replacement: step 5, image 1 of 1
      • Replace any cushioning behind the mirror.
      • While supporting the top of the mirror, set the mirror into the bottom brackets, then tighten the brackets.
      Ask FixBot
    6. Door Mirror Replacement: step 6, image 1 of 1
      • Replace the top brackets and tighten them to full secure the mirror.
      Ask FixBot
Enjoy your new mirror!
Author
with
Seth Wanderman
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 136
All Time: 1,739
