Dell XPS 12 9Q33 Battery Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
75
All Time:
1,599
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 6 minutes
Difficulty: Easy
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Battery.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Careful: steps 1-3 are sourced from a guide that's marked as in-progress.
      Dell XPS 12 9Q33 Battery Replacement, Back Cover: step 1, image 1 of 1
      • Be sure to power off and unplug your device before you begin your repair.
      • Use your fingers or a spudger to pry up the system badge from the bottom of the laptop.
      Ask FixBot
    2. Dell XPS 12 9Q33 Battery Replacement: step 2, image 1 of 1
      • Use a Phillips screwdriver to remove the eleven screws securing the base cover.
      Ask FixBot
    3. Dell XPS 12 9Q33 Battery Replacement: step 3, image 1 of 1
      • Beginning with the side opposite the power switch, use your fingers to pry up the base cover from the laptop.
      • Carefully lift the base cover around the power switch and remove the cover.
      Ask FixBot
    1. Dell XPS 12 9Q33 Battery Replacement, Removing the Battery: step 4, image 1 of 1
      • Slide the battery cable connector out of its system board socket.
      • Pull parallel to the motherboard, not straight up, or you will damage the socket.
      • Remove the screws that secure the battery to the palm-rest assembly.
      • Lift and remove the battery along with its cable.
      • Slide and hold the power switch for about five seconds to ground the system board.
      Ask FixBot
2 other people completed this guide.
Johnathan Hammond
46,347 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 75
All Time: 1,599
