Dell XPS 12 9Q33 Back Cover Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
32
All Time:
161
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
This guide shows how to remove the back cover for the Dell XPS 12 9Q33 laptop. The images are sourced from the official Dell manual.
Tools
    1. Dell XPS 12 9Q33 Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • Be sure to power off and unplug your device before you begin your repair.
      • Use your fingers or a spudger to pry up the system badge from the bottom of the laptop.
      Ask FixBot
    2. Dell XPS 12 9Q33 Back Cover Replacement: step 2, image 1 of 1
      • Use a Phillips screwdriver to remove the eleven screws securing the base cover.
      Ask FixBot
    3. Dell XPS 12 9Q33 Back Cover Replacement: step 3, image 1 of 1
      • Beginning with the side opposite the power switch, use your fingers to pry up the base cover from the laptop.
      • Carefully lift the base cover around the power switch and remove the cover.
      Ask FixBot
Arthur Shi
351,226 Reputation
937 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,884 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 32
All Time: 161
