Introduction
Access the motherboard to replace the CMOS battery if your computer is having issues tracking the date and time. It is recommended to wear an anti-static wrist strap to avoid damaging the electronic components of the computer.
Remove screws securing the hard drive
Remove hard drive by pulling on the tab to slide it out.
Remove the screws securing the optical drive, then slide out the optical drive.
Turn computer over and open it.
Carefully pry off keyboard using spudger.
Remove the ribbon cable by pulling up on the tab where it is attached, then slide it out.
Unplug the smaller ribbon cable by pulling up on the tab where it is attached, then slide it out.
Unplug the motherboard cable by pulling up on the tab where it is attached, then slide it out.
Unplug the white ribbon cable by pulling up on the tab where it is attached, then slide it out.
Unplug the black and white cables connected to the Wi-Fi chip.
Locate and disconnect connecting cables on motherboard.
Flip over motherboard and locate CMOS battery
Pry off battery with spudger.
2 other people completed this guide.
2 Guide Comments
Dont wast you time for these steps because this model 3521 ,only 2nd step enough for remove cmos battery . Once remove the Surface Cover ,you can see the cmos battery .. no need to remove all the components .thanks me later .
Thank you, kind man)
