Coby KYROS MID7125 Side Lock Button Replacement
    1. Coby KYROS MID7125 Side Lock Button Replacement, Side Lock Button: step 1, image 1 of 1
      • Begin by removing back panel using the large opening tool.
      Ask FixBot
    2. Coby KYROS MID7125 Side Lock Button Replacement: step 2, image 1 of 3 Coby KYROS MID7125 Side Lock Button Replacement: step 2, image 2 of 3 Coby KYROS MID7125 Side Lock Button Replacement: step 2, image 3 of 3
      • Remove the connection of all of the ribbon cables connected to the motherboard of the device using the Plastic Spudger.
      Ask FixBot
    3. Coby KYROS MID7125 Side Lock Button Replacement: step 3, image 1 of 1
      • Use plastic Spudger to remove the battery off of the panels and and leave it unconnected until the device is being put back together.
      • Review Battery Replacement for details on how to remove battery.
      Ask FixBot
    4. Coby KYROS MID7125 Side Lock Button Replacement: step 4, image 1 of 2 Coby KYROS MID7125 Side Lock Button Replacement: step 4, image 2 of 2
      • Using the philips head screw driver size PH0, unscrew the screws holding the mother board to the device.
      Ask FixBot
    5. Coby KYROS MID7125 Side Lock Button Replacement: step 5, image 1 of 1
      • Using the plastic Spudger, pop the mother board out of place to expose the broken button piece.
      • Be sure to not pull the mother board out to much, some of the soldered wired connections may break.
      Ask FixBot
    6. Coby KYROS MID7125 Side Lock Button Replacement: step 6, image 1 of 1
      • Use the plastic Spudger to remove broken power button, and then pop in new power button after removal.
      • Reverse steps 1-5 to reassemble.
      Ask FixBot
Benjamin Foley
125 Reputation
1 Guide authored
UMass Dartmouth, Team 5-2, Martin Fall 2016 Member of UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Members
60 Guides authored
1 Guide Comment
For people wondering: Yes, this does work on a MID7120, because the MID7120's board is similar to the MID7125's board. Also, where can I get switches similar to these? My MID7120 is missing the switch so I can't turn it on.
KineTheFish - Reply Share
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 31
All Time: 515
