Coby Kyros MID7125 Battery Replacement
    1. Coby Kyros MID7125 Battery Replacement, Battery: step 1, image 1 of 1
      • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
      Ask FixBot
    2. Coby Kyros MID7125 Battery Replacement: step 2, image 1 of 1
      • Locate battery. The battery is the silver coated square shaped device on the top of the motherboard.
      Ask FixBot
    3. Coby Kyros MID7125 Battery Replacement: step 3, image 1 of 1
      • There is a small ribbon cable located under the battery. running from the volume buttons underneath the batter to main logic board.
      Ask FixBot
    4. Coby Kyros MID7125 Battery Replacement: step 4, image 1 of 1
      • Knowing the location the ribbon cable, use plastic spudger to pry off battery.
      Ask FixBot
    5. Coby Kyros MID7125 Battery Replacement: step 5, image 1 of 1
      • After the battery is free from the logic board, find the positive and negative wires that connect the battery to the motherboard
      Ask FixBot
    6. Coby Kyros MID7125 Battery Replacement: step 6, image 1 of 1
      • Using a soldering gun, heat up both soldering points.
      • Remove wires from logic board
      • Clean up soldering joints with a desoldering sucker
      • Solder the new battery wires to the same soldering points as the old battery
      • Reverse steps 1-5 to put device back together
      Ask FixBot
Ryan
108 Reputation
1 Guide authored
UMass Dartmouth, Team 5-2, Martin Fall 2016 Member of UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 690
