Introduction
Follow this guide to replace the upper drive chain on a 2018 Classen Sod Cutter model HSC18AHD.
Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the left side of the machine.
Step 8 Remove the chain guard
Careful: steps 8-10 are sourced from a guide that's marked as in-progress.
Use a 1/2 inch socket to remove the 130 mm-long bolt securing the chain guard.
Use a 1/2 inch socket to remove the two bolts securing the upper chain guard to the frame.
