Remove the chain guard
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Careful: steps 1-4 are sourced from a guide that's marked as in-progress.
      Remove the chain guard, Safety precautions: step 1, image 1 of 2 Remove the chain guard, Safety precautions: step 1, image 2 of 2
      • Make sure the engine is off and cool to the touch before you proceed.
      Ask FixBot
    2. Remove the chain guard: step 2, image 1 of 1
      • Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
      Ask FixBot
    3. Remove the chain guard: step 3, image 1 of 2 Remove the chain guard: step 3, image 2 of 2
      • Flip the gas shutoff switch next to the motor to the left into the off position.
      Ask FixBot
    4. Remove the chain guard: step 4, image 1 of 2 Remove the chain guard: step 4, image 2 of 2
      • Grab the plastic housing at the end of the spark plug wire.
      • Pull firmly to disconnect the wire from the spark plug.
      Ask FixBot
    1. Remove the chain guard, Unbolt the cutter blade: step 5, image 1 of 1
      • Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the left side of the machine.
      • You may need to use a 1/2 inch wrench in combination with the socket wrench to hold the nuts in place.
      Ask FixBot
    2. Remove the chain guard: step 6, image 1 of 1
      • Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the right side of the machine.
      Ask FixBot
    3. Remove the chain guard, Remove the cutter blade: step 7, image 1 of 3 Remove the chain guard, Remove the cutter blade: step 7, image 2 of 3 Remove the chain guard, Remove the cutter blade: step 7, image 3 of 3
      • Slide the cutter blade out from under the machine to remove it.
      • Do not handle the blade from the cutting edge.
      Ask FixBot
    1. Remove the chain guard, Remove the chain guard: step 8, image 1 of 1
      • Use a 1/2 inch socket to remove the 130 mm-long bolt securing the chain guard.
      Ask FixBot
    2. Remove the chain guard: step 9, image 1 of 1
      • Carefully tilt the sod cutter on its side.
      • Use a 9/16 inch socket to remove the nut securing the chain guard.
      Ask FixBot
    3. Remove the chain guard: step 10, image 1 of 3 Remove the chain guard: step 10, image 2 of 3 Remove the chain guard: step 10, image 3 of 3
      • Remove the chain guard.
      Ask FixBot
Finish Line
Sam Omiotek
99,962 Reputation
289 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 17
All Time: 153
