Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement
    1. Careful: steps 1-4 are sourced from a guide that's marked as in-progress.
      Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Safety precautions: step 1, image 1 of 2 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Safety precautions: step 1, image 2 of 2
      • Make sure the engine is off and cool to the touch before you proceed.
      Ask FixBot
    2. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 2, image 1 of 1
      • Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
      Ask FixBot
    3. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 3, image 1 of 2 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 3, image 2 of 2
      • Flip the gas shutoff switch next to the motor to the left into the off position.
      Ask FixBot
    4. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 4, image 1 of 2 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 4, image 2 of 2
      • Grab the plastic housing at the end of the spark plug wire.
      • Pull firmly to disconnect the wire from the spark plug.
      Ask FixBot
    1. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Unbolt the cutter blade: step 5, image 1 of 1
      • Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the left side of the machine.
      • You may need to use a 1/2 inch wrench in combination with the socket wrench to hold the nuts in place.
      Ask FixBot
    2. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 6, image 1 of 1
      • Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the right side of the machine.
      Ask FixBot
    3. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Remove the cutter blade: step 7, image 1 of 3 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Remove the cutter blade: step 7, image 2 of 3 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Remove the cutter blade: step 7, image 3 of 3
      • Slide the cutter blade out from under the machine to remove it.
      • Do not handle the blade from the cutting edge.
      Ask FixBot
    1. Careful: steps 8-10 are sourced from a guide that's marked as in-progress.
      Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Remove the chain guard: step 8, image 1 of 1
      • Use a 1/2 inch socket to remove the 130 mm-long bolt securing the chain guard.
      Ask FixBot
    2. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 9, image 1 of 1
      • Carefully tilt the sod cutter on its side.
      • Use a 9/16 inch socket to remove the nut securing the chain guard.
      Ask FixBot
    3. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 10, image 1 of 3 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 10, image 2 of 3 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 10, image 3 of 3
      • Remove the chain guard.
      Ask FixBot
    1. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Remove the lower chain: step 11, image 1 of 2 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Remove the lower chain: step 11, image 2 of 2
      • Use a marker to mark the locations for each bearing before disassembly.
      • Reference these marks during reassembly to ensure the sprocket shaft is straight and the chain is not too loose.
      Ask FixBot
    2. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 12, image 1 of 2 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 12, image 2 of 2
      • Loosen the four 1/2 inch bolts securing the sprocket shaft bearings until the sprocket shaft can freely move.
      Ask FixBot
    3. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 13, image 1 of 3 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 13, image 2 of 3 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 13, image 3 of 3
      • Rotate the wheels to turn the chain until the master link is accessible.
      • Use a pair of pliers to unclip the master link retaining plate.
      • Note the direction the retaining plate is facing.
      • Remove the master link.
      • Make sure the new master link retaining plate is installed in the same direction. If installed backwards, the plate could come off during operation.
      Ask FixBot
    4. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: step 14, image 1 of 1
      • Remove the chain.
      Ask FixBot
Sam Omiotek
99,950 Reputation
289 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 56
All Time: 2,146
