Canon EOS Rebel T3 Tripod Socket Replacement
  1. Canon EOS Rebel T3 Tripod Socket Replacement, I/F Terminal Cover: step 1, image 1 of 3 Canon EOS Rebel T3 Tripod Socket Replacement, I/F Terminal Cover: step 1, image 2 of 3 Canon EOS Rebel T3 Tripod Socket Replacement, I/F Terminal Cover: step 1, image 3 of 3
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x4.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
    Ask FixBot
  2. Canon EOS Rebel T3 Tripod Socket Replacement, Back Cover: step 2, image 1 of 2 Canon EOS Rebel T3 Tripod Socket Replacement, Back Cover: step 2, image 2 of 2
    • On the left side of the camera, remove the following screw:
    • One M1.7x4.5mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
    Ask FixBot
  3. Canon EOS Rebel T3 Tripod Socket Replacement: step 3, image 1 of 2 Canon EOS Rebel T3 Tripod Socket Replacement: step 3, image 2 of 2
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x4.5mm JIS #000 screws
    • Two M1.7x3.0mm JIS #000 screws
    Ask FixBot
  4. Canon EOS Rebel T3 Tripod Socket Replacement: step 4, image 1 of 3 Canon EOS Rebel T3 Tripod Socket Replacement: step 4, image 2 of 3 Canon EOS Rebel T3 Tripod Socket Replacement: step 4, image 3 of 3
    • Carefully lift the back cover partially off of the camera.
    • There are two ribbon cables still connecting the back cover to the camera.
    • Disconnect the right most ribbon cables from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Pull out the ribbon cable from its connector using a pair of angled tweezers.
    • With this ribbon cable disconnected, you will be able to move the back cover slightly farther away from the camera, giving you more room to remove the remaining ribbon cable.
    • Remove the left ribbon cable using the same two steps as with the other ribbon cable.
    Ask FixBot
  5. Canon EOS Rebel T3 Tripod Socket Replacement, Front Cover: step 5, image 1 of 1
    • Remove the following screws on the front of the camera.
    • Two M1.7x5.5mm JIS #000 screws
    Ask FixBot
  6. Canon EOS Rebel T3 Tripod Socket Replacement: step 6, image 1 of 1
    • On the bottom of the camera, remove the following screws:
    Ask FixBot
  7. Canon EOS Rebel T3 Tripod Socket Replacement: step 7, image 1 of 3 Canon EOS Rebel T3 Tripod Socket Replacement: step 7, image 2 of 3 Canon EOS Rebel T3 Tripod Socket Replacement: step 7, image 3 of 3
    • Slide a spudger tool towards the tripod mount, underneath the plastic cover.
    • Push the plastic cover up and over the tripod mount.
    • Pull the front cover off of the camera.
    • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
    Ask FixBot
  8. Canon EOS Rebel T3 Tripod Socket Replacement, Tripod Socket: step 8, image 1 of 1
    • On the bottom of the camera, remove the following screws from the tripod socket plate:
    • Two M2.0x3.5mm JIS #000 screws
    • Two M2.0x5.0mm Phillips #000 screws
    • Pull off the tripod socket plate.
    Ask FixBot
Attached Documents
Zephosk
5,552 Reputation
39 Guides authored
LGBTQ Technicians Member of LGBTQ Technicians
Community
58 Members
101 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 227
