Introduction
This guide shows you how to remove the front cover if you either need to replace the cover, or in order to access other parts inside of the camera.
If you're replacing, the front covers for the Canon EOS Rebel T2i, Canon EOS Kiss X4, and Canon EOS 550D are all compatible with each other (since they are all the same camera, just rebranded for different countries). If you buy a front cover that has a name plate that has one of the other model names than the camera you have, you can always switch it out from the one from your broken front cover (it's held on with adhesive). Front cover replacement parts won't always include a name plate though.
Pry open the rubber I/F terminal cap with your finger.
Remove the two M1.7x2.5mm JIS #000 screws that are underneath the I/F terminal cap.
Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
On the left side of the camera, remove the following screw:
One M1.7x6.0mm JIS #000 screw
On the right side, remove the following screws:
One M1.7x5.5mm JIS #000 screw
One M1.7x3.5mm JIS #000 screw
Slide the viewfinder eyepiece vertically upwards.
Start to pull the back cover partially off of the camera.
Disconnect the LCD screen ribbon cable from the main PCB board.
Use a plastic spudger to lift up the black locking tab.
Carefully pull out the ribbon cable from its connector using a pair of angled tweezers.
Finish pulling the back cover off of the camera body.
Remove the following screws from the front of the camera:
Two M1.7x5.5mm JIS #000 screws
On the bottom of the camera, remove the following screws:
Three M1.7x5.5mm JIS #000 screws
