Apple Watch Series 7 Battery Replacement
Views: 185K
View statistics:
Past 24 Hours:
151
Past 7 Days:
1,149
Past 30 Days:
5,358
All Time:
185,394
Comments: 35
21 comments on steps, 14 guide comments.
Go to guide comments
Completed: 34
34 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 50 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a worn-out or dead battery in your Apple Watch Series 7.
Note: The battery replacement procedure for the 41 mm Series 7 Apple Watch differs slightly from the 45 mm version. This guide shows how to replace the battery for both sizes.
Before you begin, make sure you have the appropriate replacement battery for your watch. You will only need a Tri-point Y000 screwdriver during the battery replacement in the 45 mm model.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair.
This guide shows the procedure on the cellular/LTE version of the watch, but the GPS-only version is similar.
You’ll need replacement adhesive to reattach components when reassembling the device.
Parts
Tools
    1. Apple Watch Series 7 Battery Replacement, Power down the watch: step 1, image 1 of 2 Apple Watch Series 7 Battery Replacement, Power down the watch: step 1, image 2 of 2
      Ask FixBot
    2. Apple Watch Series 7 Battery Replacement, Safety Requirements: step 2, image 1 of 3 Apple Watch Series 7 Battery Replacement, Safety Requirements: step 2, image 2 of 3 Apple Watch Series 7 Battery Replacement, Safety Requirements: step 2, image 3 of 3
      • Because the gap between the screen and watch body is so thin, an iFlex is needed to separate the two.
      • Protect your fingers by keeping them completely clear of the iFlex edge. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
      • Be careful not to apply too much pressure, as this might cause the iFlex to slip and cut you, or damage the watch.
      • Wear eye protection. If the opening procedure is performed incorrectly or with too much pressure, the glass could crack, sending small glass shards flying.
      • Attach or remove the watch band as needed to provide more control as you make repairs.
      Ask FixBot
    3. Apple Watch Series 7 Battery Replacement, Soften the display adhesive: step 3, image 1 of 1
      • Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the watch—the display and internal battery are both susceptible to heat damage.
      • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive softens.
      Ask FixBot
    4. Apple Watch Series 7 Battery Replacement, Create a gap: step 4, image 1 of 3 Apple Watch Series 7 Battery Replacement, Create a gap: step 4, image 2 of 3 Apple Watch Series 7 Battery Replacement, Create a gap: step 4, image 3 of 3
      Tool used on this step:
      Cut-Resistant ESD Gloves
      $19.99
      Buy
      • Don't grip the iFlex or similar metal tools by the edges—they're very sharp. Consider wearing gloves to protect your hands.
      • Insert the iFlex at a downward angle between the bottom edge of the screen and frame.
      • The Apple Watch Series 7 display is equipped with a plastic bezel on its rear side. If you want to reuse your display, avoid using too much pressure with the iFlex or you may separate the bezel from the screen.
      Ask FixBot
    5. Apple Watch Series 7 Battery Replacement, Pry up the screen: step 5, image 1 of 2 Apple Watch Series 7 Battery Replacement, Pry up the screen: step 5, image 2 of 2
      • Prying up the screen may take multiple attempts. If you're having trouble, apply more heat and try again.
      • With one hand, push down firmly on the watch's frame to secure it in place.
      • With your free hand, hold the iFlex and push the edges up to make it more rigid.
      • The iFlex should be slightly "U" shaped.
      • Pry up the screen enough for the iFlex to lay flat on its own.
      • The iFlex doesn't need to be inserted far, as it can easily damage the screen cables near the bottom right corner of the watch.
      • Leave the iFlex inserted under the screen.
      Ask FixBot
    6. Apple Watch Series 7 Battery Replacement, Insert an opening pick: step 6, image 1 of 3 Apple Watch Series 7 Battery Replacement, Insert an opening pick: step 6, image 2 of 3 Apple Watch Series 7 Battery Replacement, Insert an opening pick: step 6, image 3 of 3
      • Do not insert your opening pick more than 3 mm under the screen when separating the adhesive, as you risk damaging your watches internals.
      • Keep the iFlex flat to maintain a gap between the screen and frame while inserting an opening pick.
      • Insert an opening pick between the screen and iFlex.
      • Remove the iFlex.
      Ask FixBot
    7. Apple Watch Series 7 Battery Replacement, Slice the adhesive: step 7, image 1 of 2 Apple Watch Series 7 Battery Replacement, Slice the adhesive: step 7, image 2 of 2
      • Slide the opening pick around the bottom left corner and up the left edge.
      Ask FixBot
    8. Apple Watch Series 7 Battery Replacement: step 8, image 1 of 2 Apple Watch Series 7 Battery Replacement: step 8, image 2 of 2
      • Slide the opening pick around the corner and along the long edge on the opposite side of the watch crown to slice the display adhesive.
      Ask FixBot
    9. Apple Watch Series 7 Battery Replacement: step 9, image 1 of 2 Apple Watch Series 7 Battery Replacement: step 9, image 2 of 2
      • Slide the opening pick around the corner to slice the remaining adhesive on the short edge of the watch next to the watch crown.
      • Don't try to remove the display. It is still connected to the watch assembly.
      Ask FixBot
    10. Apple Watch Series 7 Battery Replacement, Swing open the display: step 10, image 1 of 3 Apple Watch Series 7 Battery Replacement, Swing open the display: step 10, image 2 of 3 Apple Watch Series 7 Battery Replacement, Swing open the display: step 10, image 3 of 3
      • Be careful not to strain the display cables when you fold the display to the side.
      • Lift the display and carefully pull it towards the watch crown.
      • Swing the display open to an upward position.
      Ask FixBot
    1. Apple Watch Series 7 Battery Replacement, Soften the battery adhesive: step 11, image 1 of 1
      • Prepare an iOpener and apply it to the rear side of your Apple Watch for at least two minutes to loosen the adhesive underneath the battery.
      Ask FixBot
    2. Apple Watch Series 7 Battery Replacement, Determine which procedure to follow: step 12, image 1 of 1
      • From this point, the battery removal procedure for the 41 mm watch differs slightly from the 45 mm version.
      • If you're replacing the battery for a 41 mm watch, continue with this step.
      • If you're replacing the battery for a 45 mm watch, continue with this step.
      Ask FixBot
    3. Apple Watch Series 7 Battery Replacement, Pry up the battery: step 13, image 1 of 3 Apple Watch Series 7 Battery Replacement, Pry up the battery: step 13, image 2 of 3 Apple Watch Series 7 Battery Replacement, Pry up the battery: step 13, image 3 of 3
      • The following six steps show how to remove the battery from a 41 mm Apple Watch Series 7.
      • Insert an opening pick between watch body and the long edge of the battery.
      • Use constant, steady pressure to slowly pry up the battery.
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      • Don't try to remove the battery all the way yet. It is still connected to the motherboard.
      Ask FixBot
    4. Apple Watch Series 7 Battery Replacement, Move the battery: step 14, image 1 of 2 Apple Watch Series 7 Battery Replacement, Move the battery: step 14, image 2 of 2
      • The battery flex cable is long enough to allow you to place the battery outside the watch housing, but avoid straining or folding the the cable sharply when you lift the battery out of its recess.
      • Carefully lift and swing the battery out of its recess and place it next to the watch body.
      Ask FixBot
    5. Apple Watch Series 7 Battery Replacement, Peel the black protective tape off the ZIF connector: step 15, image 1 of 2 Apple Watch Series 7 Battery Replacement, Peel the black protective tape off the ZIF connector: step 15, image 2 of 2
      Buy
      • Use a pair of tweezers to peel the black protective tape off the ZIF connector.
      • Make sure to only peel the tape off the connector but avoid to remove it completely. Otherwise you have to replace the tape during reassembly.
      Ask FixBot
    6. Apple Watch Series 7 Battery Replacement, Open the ZIF connector: step 16, image 1 of 2 Apple Watch Series 7 Battery Replacement, Open the ZIF connector: step 16, image 2 of 2
      • Use one arm of your tweezers or the pointed end of a spudger to pry up the lock bar on the ZIF connector securing the battery cable.
      Ask FixBot
    7. Apple Watch Series 7 Battery Replacement, Disconnect the battery: step 17, image 1 of 2 Apple Watch Series 7 Battery Replacement, Disconnect the battery: step 17, image 2 of 2
      • Use a pair of tweezers to pull the battery cable out of the battery ZIF connector.
      • During reassembly make sure to push the cable all the way back into the ZIF connector before locking the it. Reapply the black tape on top of the connector to secure the battery cable or replace it with new one. Otherwise the battery cable may slip out of the connector and your watch won't turn on.
      Ask FixBot
    8. Apple Watch Series 7 Battery Replacement, Remove the battery: step 18, image 1 of 1
      • Remove the battery.
      • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
      • If you're reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly.
      • Secure a new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
      Ask FixBot
    9. Apple Watch Series 7 Battery Replacement, Pry up the battery: step 19, image 1 of 3 Apple Watch Series 7 Battery Replacement, Pry up the battery: step 19, image 2 of 3 Apple Watch Series 7 Battery Replacement, Pry up the battery: step 19, image 3 of 3
      • The following six steps show how to remove the battery from a 45 mm Apple Watch Series 7.
      Ask FixBot
    10. Apple Watch Series 7 Battery Replacement, Move the battery: step 20, image 1 of 2 Apple Watch Series 7 Battery Replacement, Move the battery: step 20, image 2 of 2
      Ask FixBot
    11. Apple Watch Series 7 Battery Replacement, Unfasten the battery connector bracket screw: step 21, image 1 of 1
      • Use a Tri-Point Y000 screwdriver to remove the 1.1 mm-long screw securing the battery connector bracket.
      Ask FixBot
    12. Apple Watch Series 7 Battery Replacement, Remove the battery connector bracket: step 22, image 1 of 2 Apple Watch Series 7 Battery Replacement, Remove the battery connector bracket: step 22, image 2 of 2
      • Use a pair of tweezers to remove the battery connector bracket.
      Ask FixBot
    13. Apple Watch Series 7 Battery Replacement, Disconnect the battery cable: step 23, image 1 of 2 Apple Watch Series 7 Battery Replacement, Disconnect the battery cable: step 23, image 2 of 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      Ask FixBot
    14. Apple Watch Series 7 Battery Replacement, Remove the battery: step 24, image 1 of 1
      • If you're reusing your old battery, you can reuse the existing adhesive to secure the battery during reassembly.
      • During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
34 other people completed this guide.
Dominik Schnabelrauch
266,179 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
14 Guide Comments
Is it still waterproof after that? I swim daily. Watch is 2.5 years old doing great but the battery is at 76%.
Will the adhesive on the screen seal back up good enough?
Matt Reason - Reply Share
Hi Matt,
retaining water resistance after the repair depends on how clean the mating surfaces are and how accurately the adhesive is reapplied. Your device will lose its factory-given IP (Ingress Protection) rating. Personally I wouldn‘t advise to go swimming with the watch after resealing it with tape.
Dominik Schnabelrauch - Reply Share
if the socket that the battery plugs into breaks, is that something worth paying to fix, or should i just buy a new watch?
river D - Reply Share
Bravissimo,tutto molto chiaro.
Aldo Sammartano - Reply Share
will battery health show 100% after the replacement battery is installed? or will it still show service recommended? thanks!
joseetan - Reply Share
Past 24 Hours: 151
Past 7 Days: 1,149
Past 30 Days: 5,358
All Time: 185,394
