Apple Watch Series 5 Battery Replacement
Views: 168K
View statistics:
Past 24 Hours:
89
Past 7 Days:
592
Past 30 Days:
2,763
All Time:
168,251
Comments: 20
11 comments on steps, 9 guide comments.
Go to guide comments
Completed: 46
46 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 50 minutes - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a worn-out or dead battery in your Apple Watch Series 5.
This guide shows the procedure on the cellular/LTE version of the watch, but the GPS-only version is similar.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your watch. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
During the display opening procedure of the Apple Watch you might damage the force touch gasket. If you separate the gasket layers or cut the cable, you'll also need to replace the Force Touch gasket itself.
You’ll need replacement adhesive to reattach components when reassembling the device.
Parts
Tools
    1. Apple Watch Series 5 Battery Replacement, Display Opening: step 1, image 1 of 2 Apple Watch Series 5 Battery Replacement, Display Opening: step 1, image 2 of 2
      Ask FixBot
    2. Apple Watch Series 5 Battery Replacement, Safety Requirements: step 2, image 1 of 3 Apple Watch Series 5 Battery Replacement, Safety Requirements: step 2, image 2 of 3 Apple Watch Series 5 Battery Replacement, Safety Requirements: step 2, image 3 of 3
      • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
      • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
      • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
      • Wear eye protection. The knife or glass may break, sending pieces flying.
      • Attach or remove the watch band as needed to provide more control as you make repairs.
      Ask FixBot
    3. Apple Watch Series 5 Battery Replacement: step 3, image 1 of 1
      • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
      • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
      • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive softens.
      Ask FixBot
    4. Apple Watch Series 5 Battery Replacement: step 4, image 1 of 3 Apple Watch Series 5 Battery Replacement: step 4, image 2 of 3 Apple Watch Series 5 Battery Replacement: step 4, image 3 of 3
      • Take your time and work carefully to avoid scratching the watch body with your iFlex.
      • Don't insert the iFlex more than 1/16th of an inch (~2 mm) to avoid damaging the force touch sensor.
      • Insert the iFlex into the thin gap between the display and frame at the edge adjacent to the digital crown.
      • Tilt the iFlex down to pry the display open slightly and create a gap between the screen and the watch body.
      Ask FixBot
    5. Apple Watch Series 5 Battery Replacement: step 5, image 1 of 2 Apple Watch Series 5 Battery Replacement: step 5, image 2 of 2
      • Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
      • Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
      • Don't try to fully open or detach the display yet.
      Ask FixBot
    6. Apple Watch Series 5 Battery Replacement: step 6, image 1 of 3 Apple Watch Series 5 Battery Replacement: step 6, image 2 of 3 Apple Watch Series 5 Battery Replacement: step 6, image 3 of 3
      • It's likely that the force touch sensor will stick to the display frame instead to the watch's body. In this case, insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
      • To preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
      • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
      • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm) to avoid damaging other components.
      Ask FixBot
    7. Apple Watch Series 5 Battery Replacement: step 7, image 1 of 2 Apple Watch Series 5 Battery Replacement: step 7, image 2 of 2
      • Avoid tensioning the display cables when folding the screen to the back.
      • Carefully lift the display open like a book.
      Ask FixBot
    1. Apple Watch Series 5 Battery Replacement, Battery: step 8, image 1 of 2 Apple Watch Series 5 Battery Replacement, Battery: step 8, image 2 of 2
      • Lift the screen until there's enough space to access the battery.
      • Insert an opening pick between the battery and the Taptic Engine.
      • A regular opening pick works fine with the 44 mm version of the Apple Watch Series 5. However if you own the 40 mm version and don't have enough space you can customize your opening pick with scissors.
      Ask FixBot
    2. Apple Watch Series 5 Battery Replacement, Pry up the Battery: step 9, image 1 of 3 Apple Watch Series 5 Battery Replacement, Pry up the Battery: step 9, image 2 of 3 Apple Watch Series 5 Battery Replacement, Pry up the Battery: step 9, image 3 of 3
      • Slide the opening pick along the edge of the battery to loosen the adhesive.
      • The battery adhesive is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive. Apply the iOpener for at least two minutes.
      • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the mainboard.
      • Avoid damaging the display cables, and especially the force touch cable, which covers the battery in one corner during the prying procedure.
      • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
      • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
      Ask FixBot
    3. Apple Watch Series 5 Battery Replacement: step 10, image 1 of 1
      • Carefully lift the battery to a 75-degree angle.
      • Remove the 1.1 mm-long Y000 screw.
      Ask FixBot
    4. Apple Watch Series 5 Battery Replacement, Remove The Metal Plate: step 11, image 1 of 2 Apple Watch Series 5 Battery Replacement, Remove The Metal Plate: step 11, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the metal plate covering the battery connector.
      Ask FixBot
    5. Apple Watch Series 5 Battery Replacement, Disconnect the battery: step 12, image 1 of 2 Apple Watch Series 5 Battery Replacement, Disconnect the battery: step 12, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
      Ask FixBot
    6. Apple Watch Series 5 Battery Replacement, Remove the Battery: step 13, image 1 of 2 Apple Watch Series 5 Battery Replacement, Remove the Battery: step 13, image 2 of 2
      Tesa 61395 Tape
      $8.95
      Buy
      • Remove the battery.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • If you are reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly. Alternatively, remove the old adhesive with high isopropyl alcohol and a lint free cloth and use a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
      • Follow the resealing guide to reseal your watch after reassembly.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
46 other people completed this guide.
Dominik Schnabelrauch
266,702 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
9 Guide Comments
Since WatchOS 7 removed 3D Touch functionality on all Force Touch enabled watches, will damaging or disconnecting the Force Touch gasket affect the functionality of the watch or will the software brick it?
AStupidMidge - Reply Share
Any tips for applying the adhesive strip without removing the screen? Is removing the screen recommended to seat it properly?
David Mifsud - Reply Share
Does the resealing adhesive strip go in between the screen and force touch gasket, or the force touch gasket and the case?
Hi David,
here is a general resealing guide that might help you. Depending on your force touch replacement part you‘ll need one two or no adhesive strips.
If your force touch was never removed you need to place new adhesive on top of it the adhere the screen. If your force touch has adhesive on the bottom side it is the same. Adhere the force touch into the watch frame and place adhesive on top of it to adhere the screen. If there is adhesive on the top of the force touch you need to place the adhesive strip beneath.
If your force touch didn‘t come with any adhesive preinstalled you need adhesive tape below to secure it to the watch frame and on top to secure the screen.
Dominik Schnabelrauch - Reply Share
Hi @schnabel , thank you for you reply. I am in the middle of replacing the battery. I managed to save the force touch sensor from getting damaged, but I need to be re-adhere it to both surfaces. Can I use 2 of these adhesive strips on either side?
Apple Watch (44 mm Series 4/5) Screen Adhesive
Past 24 Hours: 89
Past 7 Days: 592
Past 30 Days: 2,763
All Time: 168,251
