Up to 20% off select tools
Apple Lisa SCSI Card Installation
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
67
All Time:
1,128
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. Apple Lisa SCSI Card Installation, Disassembly: step 1, image 1 of 2 Apple Lisa SCSI Card Installation, Disassembly: step 1, image 2 of 2
      Ask FixBot
    2. Apple Lisa SCSI Card Installation, Installing the SCSI Card: step 2, image 1 of 2 Apple Lisa SCSI Card Installation, Installing the SCSI Card: step 2, image 2 of 2
      • Locate Lisa's expansion slots.
      • Locate expansion slot 3.
      • Pull the metal rod out from slot 3 and rotate 90º clockwise.
      • Slide the SCSI Card into expansion slot 3.
      • Rotate the metal rod, as described before, 90º counter-clockwise and push in to secure the Lisa DAC.
      Ask FixBot
      • The SCSI card includes 1 internal connector and 1 external connector.
      • The internal connector is used for connecting a hard disk.
      • If you intend to connect a hard disk then connect it now.
      • Pin 1 is marked.
      • The SCSI Card can also be cut to accommodate a Card Cage fan upon order request.
      Ask FixBot
    3. Apple Lisa SCSI Card Installation, Reinstall Rear Panel: step 4, image 1 of 1
      • Reinstall the Lisa's rear panel.
      Ask FixBot
    4. Apple Lisa SCSI Card Installation, Using the SCSI Card: step 5, image 1 of 1
      • The SCSI Card requires MacWorks Plus II.
      • To use devices connected to the SCSI card please refer to the device's manual for proper device installation.
      • This SCSI card was installed to use an Apple External SCSI CD-ROM Drive.
      Ask FixBot
Author
with
LisaGuide
1,833 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 67
All Time: 1,128
