Up to 20% off select tools
Apple Lisa Disassembly
Views: 3.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
70
All Time:
3,427
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. Apple Lisa Disassembly, Prepare Workspace: step 1, image 1 of 1
      • Place the Lisa on a safe/sturdy surface.
      Ask FixBot
    2. Apple Lisa Disassembly, Removing Front Panel: step 2, image 1 of 2 Apple Lisa Disassembly, Removing Front Panel: step 2, image 2 of 2
      • Press the two tabs underneath to release the panel.
      Ask FixBot
    3. Apple Lisa Disassembly, Remove Drive Cage: step 3, image 1 of 1
      • Release the thumbscrew underneath the drive cage and the cage will pull out. Disconnect drive wires while the cage is being removed.
      Ask FixBot
    4. Apple Lisa Disassembly, Remove Back Panel: step 4, image 1 of 2 Apple Lisa Disassembly, Remove Back Panel: step 4, image 2 of 2
      • Twist thumbscrews on the back to release the panel. Pull panel up to remove.
      Ask FixBot
    5. Apple Lisa Disassembly, Remove Power Supply: step 5, image 1 of 3 Apple Lisa Disassembly, Remove Power Supply: step 5, image 2 of 3 Apple Lisa Disassembly, Remove Power Supply: step 5, image 3 of 3
      • Release the thumbscrew on the power supply. Pull out the power supply.
      Ask FixBot
    6. Apple Lisa Disassembly, Remove Cardcage: step 6, image 1 of 2 Apple Lisa Disassembly, Remove Cardcage: step 6, image 2 of 2
      • Grab the card cage at the location shown and pull out.
      Ask FixBot
    7. Apple Lisa Disassembly, Remove Top: step 7, image 1 of 2 Apple Lisa Disassembly, Remove Top: step 7, image 2 of 2
      • Unscrew two philips screws on the ceiling of where the card cage was.
      Ask FixBot
    8. Apple Lisa Disassembly, Remove Power Switch: step 8, image 1 of 2 Apple Lisa Disassembly, Remove Power Switch: step 8, image 2 of 2
      • Release two screws and release the ribbon cable.
      Ask FixBot
    9. Apple Lisa Disassembly, Remove Right Panel: step 9, image 1 of 3 Apple Lisa Disassembly, Remove Right Panel: step 9, image 2 of 3 Apple Lisa Disassembly, Remove Right Panel: step 9, image 3 of 3
      • Remove all screws shown.
      Ask FixBot
    10. Apple Lisa Disassembly, Remove Left Panel: step 10, image 1 of 2 Apple Lisa Disassembly, Remove Left Panel: step 10, image 2 of 2
      Ask FixBot
    11. Apple Lisa Disassembly, Remove Feet Panel: step 11, image 1 of 1
      Ask FixBot
    12. Apple Lisa Disassembly, Remove Bottom Pannel: step 12, image 1 of 1
      Ask FixBot
    13. Apple Lisa Disassembly, CRT: step 13, image 1 of 1
      • I am not a certified CRT technician so I am not suppling steps on how to remove it although here is a photo of the innards.
      Ask FixBot
    14. Apple Lisa Disassembly, Remove Cards: step 14, image 1 of 3 Apple Lisa Disassembly, Remove Cards: step 14, image 2 of 3 Apple Lisa Disassembly, Remove Cards: step 14, image 3 of 3
      • Pull up on the tabs to remove cards.
      Ask FixBot
    15. Apple Lisa Disassembly, Remove Card Mount: step 15, image 1 of 3 Apple Lisa Disassembly, Remove Card Mount: step 15, image 2 of 3 Apple Lisa Disassembly, Remove Card Mount: step 15, image 3 of 3
      Ask FixBot
4 other people completed this guide.
Author
with
LisaGuide
1,833 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 70
All Time: 3,427
