AcousticSheep SleepPhones Battery Replacement
    1. AcousticSheep SleepPhones Battery Replacement, Take out the Bluetooth module: step 1, image 1 of 1
      • Just like when charging the device, take out the Bluetooth module from the headband and disconnect it from the speakers.
      Ask FixBot
    2. AcousticSheep SleepPhones Battery Replacement, Pry off the back of the module: step 2, image 1 of 2 AcousticSheep SleepPhones Battery Replacement, Pry off the back of the module: step 2, image 2 of 2
      • The back cover is glued in place. It's not a very tough glue, so the cover may have already shifted a bit from its place, and it shouldn't be too hard to remove.
      Ask FixBot
      • The module has two compartments, one for the battery and one for the circuit board. Remove both from their rubbery shell.
      Ask FixBot
      • You may be able to cleanly remove the two wires from the beige clip, but I wasn't confident I would be able to reconnect them, so I cut them near the battery, so I had plenty of wire to attach the new battery to.
      Ask FixBot
      • The original battery is a prismatic LiPo 3.7 V 330mAh with dimensions 4x28x26 mm
      • The connector used on the battery is a HIROSE DF57(AH), 1.2mm pitch, 2-position. They can be found on DigiKey along with their header and pins.
      • I wasn't able to find one of that exact size, but since it fit even in its swollen state, I figured I could go for a thicker 6x28x23 mm battery
      Ask FixBot
    3. AcousticSheep SleepPhones Battery Replacement, Connect the new battery: step 6, image 1 of 1
      • Solder or twist together the old and new battery wires
      • Cover the exposed parts with electrical tape
      Ask FixBot
      • You can test your repairs without replacing everything into its protective cover first. This can save you some frustration when it doesn't work on the first try, but requires a bit more caution when handling the circuit board.
      • Long press the central button on the circuit board to turn it on. Does the red LED blink on?
      • Does it connect to your device?
      • Attach the speakers and try to play some audio
      • Attach a charger. Does the charging light come on?
      Ask FixBot
    4. AcousticSheep SleepPhones Battery Replacement, Replace the components back into the rubber case: step 8, image 1 of 1
      • You can look at the opening for the USB port to check the orientation (this is one place where USB-C would be a disadvantage)
      • It might take some patience to guide the wires through the opening between the two compartments. In my case it was easier to turn the battery sideways.
      Ask FixBot
      • In my case, it remained sticky enough to not require new glue, even after several disassemblies.
      Ask FixBot
Finish Line
2 other people completed this guide.
hgjd
359 Reputation
2 Guides authored
5 Guide Comments
I ended up removing the bad battery connector altogether from the battery wires. Then I soldered the negative side to the capacitor just below the connector on the board, and the positive side to the positive pin in the board connector. Finally I managed to get some glue gun glue on it.
https://imgur.com/a/sCySO7Q
Thomas - Reply Share
Do you have a link to the supplier of the replacment battery?
Joe Noir - Reply Share
I had the problem of loose battery connector terminals happen on the SleepPhones Effortless as well. Same solution: Solder the battery to the boar. There is an unpopulated capacitor one case use if the wires are long enough. Otherwise, carefully solder to the connector terminals. Photo: https://imgur.com/a/6uOM8CR
For anyone who finds this in the future, here is the information about the connector. It is a HIROSE DF57(AH). 1.2mm pitch. Took a long time to figure this one out, and this post was the first Google result that I really wish had the answer.
Here is what you need.
1. The connector
2. The pins
3. (Optional - if you need to replace the header) The header
You'll need a crimping tool for the pins. You can find a generic one on amazon for cheap. Don't look at the ones by Romex or HIROSE; they're priced to be part of a huge corporate budget. 28 gauge wire.
Brenden Smith - Reply Share
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 80
All Time: 2,904
