Tools
Introduction
Go to step 1 ↓This is a step-by-step guide to replace the screen of your Abask J05 dashcam.
The screen is a 1.5” thick, double-layered pane of glass with a thin liquid crystal layer in-between. Its function is to display information. A broken or faulty screen could prevent information from being displayed properly. If your screen flickers uncontrollably, freezes repeatedly, and/or turns black/white, it might be in need of replacement. Before replacing the screen, be sure to review the troubleshooting guide as there might be other reasons your screen is malfunctioning that don’t require replacement.
Gently press on the SD card with a fingernail until it clicks.
Release, then remove the card.
Remove the two 7 mm screws on the side of the motherboard with a Phillips #00 screwdriver.
Slowly pull up on each corner of the motherboard, stopping when the corner pops loose of the anchor.
Repeat the process with each corner before slowly pulling up on the board to detach the glue on the underside.
To reassemble your device, follow these instructions in reverse order. (Note: When doing the steps in reverse order, do not do Step 5. Instead, place the front face of the device back on the main body before lining up the endcap, ensuring proper orientation with the SD card slot, and push in until you hear all four snap joints snap into place.)
2 other people completed this guide.
