Up to 20% off select tools
AT-LP60X Mechanical Reset
Views: 4.8K
View statistics:
Past 24 Hours:
28
Past 7 Days:
159
Past 30 Days:
532
All Time:
4,812
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Very easy
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Introduction
Go to step 1 ↓
Step-By-Step Guide: Created By ATUS Service
This guide is used to provide step-by-step instructions for performing a mechanical reset on all AT-LP60/LP60X, AT-LP3/LP3X, and AT-LP70X models. This procedure is used to resolve some instances of inconsistent functionality of the auto start/stop function of the automatic turntable.
There are no replacement parts or tools required to perform this procedure.
    1. AT-LP60X Mechanical Reset, Remove Power From The Turntable: step 1, image 1 of 1
      • Unplug the power source located on the back of the turntable.
      Ask FixBot
    2. AT-LP60X Mechanical Reset, Press The Stop Button: step 2, image 1 of 1
      • Press the stop button located at the front of the turntable one time.
      • During this step, remove your record (if one is on the turntable) and remove the black felt mat.
      Ask FixBot
    3. AT-LP60X Mechanical Reset, Perform Mechanical Reset: step 3, image 1 of 1
      • With your right hand, hold the tone arm in the rest so that it does not move.
      • With your left hand, slowly rotate the platter clockwise until you hear a series of clicks.
      • After hearing the series of clicks, the cam gear assembly should not rotate while the platter is spinning - if the cam gear is still rotating, press the stop button again and repeat Step 3.
      • Cam gear assembly - white gear visible through holes of the platter.
      • Allowing the tone arm to move freely during this process can result in the stylus being broken.
      Ask FixBot
Finish Line
Author
with
Anthony @ ATUS
1,290 Reputation
6 Guides authored
2 Guide Comments
Y si aún así no funciona?
Roberto Sarmiento - Reply Share
@robertosar31545 La otra solución habitual para resolver problemas con las funciones de inicio y parada automáticos es volver a colocar o reemplazar el engranaje de leva (cam gear): AT-LP60X Cam Gear Assembly Replacement
Si sigue esta guía, puede intentar retirar y volver a colocar el engranaje de leva que actualmente tiene su tocadiscos.
Si esto no soluciona el problema, le recomendaría ponerse en contacto con el equipo local de soporte técnico de Audio-Technica a través del siguiente enlace:
https://www.at-globalsupport.com/
ATUS Service Dept - Reply Share
Past 24 Hours: 28
Past 7 Days: 159
Past 30 Days: 532
All Time: 4,812
