AT-LP60X Cam Gear Assembly Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
58
Past 30 Days:
278
All Time:
2,568
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Step-By-Step Guide: Created By ATUS Service
This guide is used to provide step-by-step instructions for replacing or reseating the Cam Gear Assembly on all AT-LP60/LP60X, AT-LP3/LP3X, and AT-LP70X models. The part being replaced has a possible link to inconsistent functionality of the auto start/stop function of the automatic turntable.
The part number for the cam gear assembly is 701-SL24F-192, and can be purchased through the Audio-Technica parts department; (330)686-2600 ext.5002 || parts@atus.com
Parts
Tools
    1. AT-LP60X Cam Gear Assembly Replacement, Remove Power From The Turntable: step 1, image 1 of 1
      • Unplug the power source located on the back of the turntable.
      Ask FixBot
    2. AT-LP60X Cam Gear Assembly Replacement, Press The Stop Button: step 2, image 1 of 1
      • Press the stop button located at the front of the turntable one time.
      • During this step, remove your record (if one is on the turntable) and remove the black felt mat.
      Ask FixBot
    3. AT-LP60X Cam Gear Assembly Replacement, Perform Mechanical Reset: step 3, image 1 of 1
      • With your right hand, hold the tone arm in the rest so that it does not move.
      • With your left hand, slowly rotate the platter clockwise until you hear a series of clicks.
      • After hearing the series of clicks, the cam gear assembly should not rotate while you continue to rotate the platter - if the cam gear is still rotating, press the stop button again and repeat step 3.
      • Cam gear assembly - white gear visible through holes of the platter.
      • Allowing the tone arm to move freely during this process can result in the stylus being broken.
      Ask FixBot
    4. AT-LP60X Cam Gear Assembly Replacement, Detach Belt & Remove Platter: step 4, image 1 of 2 AT-LP60X Cam Gear Assembly Replacement, Detach Belt & Remove Platter: step 4, image 2 of 2
      • Gently pull the belt up and off of the gold pulley.
      • Remove the platter by grabbing the platter from the two circles, and pull straight up.
      Ask FixBot
    5. AT-LP60X Cam Gear Assembly Replacement, Remove Screw: step 5, image 1 of 1
      • Remove the screw in the center of the cam gear assembly.
      • Keep screw for Step 9.
      Ask FixBot
    6. AT-LP60X Cam Gear Assembly Replacement, Remove Cam Gear Assembly: step 6, image 1 of 2 AT-LP60X Cam Gear Assembly Replacement, Remove Cam Gear Assembly: step 6, image 2 of 2
      • Once the screw is removed, pull the cam gear directly up to remove it.
      • Flip the cam gear upside-down and adjust the curved metal piece to be inwards
      Ask FixBot
    7. AT-LP60X Cam Gear Assembly Replacement, Adjust Shaft Assembly: step 7, image 1 of 1
      • Position the metal shaft against the metal bar.
      • Ensure brass bushing is lying flat in between the grooves.
      • Position the white plastic part such that it is touching the hole closest to the center post.
      Ask FixBot
    8. AT-LP60X Cam Gear Assembly Replacement, Position New Cam Gear Assembly: step 8, image 1 of 2 AT-LP60X Cam Gear Assembly Replacement, Position New Cam Gear Assembly: step 8, image 2 of 2
      • Place the new cam gear assembly on the center post, it will fall into place once the rest of this step is complete - DO NOT force the cam gear assembly down.
      • When the cam gear is placed, the open area of the cam gear should be facing the inner spindle as shown.
      • Locate the metal hook at the end of the spring, and gently slide it away from the cam gear until the cam gear drops into position.
      Ask FixBot
    9. AT-LP60X Cam Gear Assembly Replacement, Mount New Cam Gear Assembly: step 9, image 1 of 1
      • Secure the cam gear assembly with the screw set aside from Step 5.
      Ask FixBot
    10. AT-LP60X Cam Gear Assembly Replacement, Mount Platter And Belt: step 10, image 1 of 3 AT-LP60X Cam Gear Assembly Replacement, Mount Platter And Belt: step 10, image 2 of 3 AT-LP60X Cam Gear Assembly Replacement, Mount Platter And Belt: step 10, image 3 of 3
      • Flip the platter upside-down and ensure the belt is stretched around the inner ring.
      • Mount the platter back onto the center spindle.
      • Stretch the belt around the gold pulley.
      • If the belt is connected to anything except the silver platter and the gold pulley this will cause the platter to spin inconsistently.
      Ask FixBot
    11. AT-LP60X Cam Gear Assembly Replacement, Reconnect Power: step 11, image 1 of 1
      • Reconnect the power source to the turntable.
      Ask FixBot
    12. AT-LP60X Cam Gear Assembly Replacement, Place Slipmat And Record: step 12, image 1 of 1
      • Place the slipmat back onto the platter, and try a record.
      • If the automatic start/stop function still does not work properly, the turntable would likely need to be sent in for repair. Please follow the instructions found in the warranty/repair section at the bottom of www.audio-technica.com
      • If you are sending the turntable in for repair - DO NOT SHIP ANY ACCESSORIES (DUST COVER, HINGES, BELT, PLATTER, SLIPMAT, OR CABLES). IMPROPER SHIPPING CAN CAUSE NON-REPAIRABLE DAMAGE TO THE TURNTABLE.
      Ask FixBot
Finish Line
Anthony @ ATUS
1,290 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 58
Past 30 Days: 278
All Time: 2,568
