Up to 20% off select tools
07. Heated bed
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
107
All Time:
107
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
07. Heated bed
    1. 07. Heated bed, Heated bed type: step 1, image 1 of 1
      • This chapter contains the assembly guide for the 3 heated bed of Prusa MK2(S), MK2.5(S) and MK3(S).
      • Go to the step corresponding to your Prusa heated bed type:
      • Prusa MK2(S): continue to the next step.
      • Prusa MK2.5(S): go to step 8.
      • Prusa MK3(S): go to step 14.
      Ask FixBot
    2. 07. Heated bed, Heat bed cable check - MK2(S): step 2, image 1 of 2 07. Heated bed, Heat bed cable check - MK2(S): step 2, image 2 of 2
      • On your heated bed, verify that the thermistor cable is not stretched, it should make a small curve.
      • If the cable is stretched it might move the thermistor from its position or damage the wires during printing.
      Ask FixBot
    3. 07. Heated bed, Heated bed assembly - MK2(S): step 3, image 1 of 2 07. Heated bed, Heated bed assembly - MK2(S): step 3, image 2 of 2
      • Remove the two temporary hex nuts from the Y carriage and save them for later use. Keep the M3x12 screws of the y_belt_holder in place.
      • Place the heated bed on the Y carriage.
      Ask FixBot
    4. 07. Heated bed, Heated bed assembly - MK2(S): step 4, image 1 of 3 07. Heated bed, Heated bed assembly - MK2(S): step 4, image 2 of 3 07. Heated bed, Heated bed assembly - MK2(S): step 4, image 3 of 3
      • Be careful with the extruder during this step, it will slide when you rotate the printer to access screws under the heated bed.
      • Take 4x M3x8 button head screws (reused from your Original Prusa) and secure the heated bed in the corners. Do not fully tighten the screws yet.
      • Using the 2x M3x12 screws, secure the y_belt_holder to the bed. Do not fully tighten the screws yet.
      • Fully tighten all the screws evenly, incrementally and in turn, in this precise orders (do not use excessive force or you might break the spacers):
      • 1st the screws of y_belt_holder.
      • 2nd one of the corner in diagonal.
      • 3rd the other corner in diagonal.
      • Repeat until all screws are fully tightened.
      Ask FixBot
    5. 07. Heated bed, Heat bed cable check - MK2(S): step 5, image 1 of 1
      • Verify again, that the thermistor cable is not stretched (it should make a small curve) and does not sag down too much as it could be damaged with bed movements.
      Ask FixBot
    6. 07. Heated bed, Next chapter: step 6, image 1 of 1
      Ask FixBot
    7. 07. Heated bed: step 7, image 1 of 1
      • The next steps are for MK2.5(S) heated bed only.
      • Prusa MK2(S): go to step 2.
      • Prusa MK2.5(S): continue to the next step.
      Ask FixBot
    8. 07. Heated bed, Heat bed cable check - MK2.5(S): step 8, image 1 of 2 07. Heated bed, Heat bed cable check - MK2.5(S): step 8, image 2 of 2
      Ask FixBot
    9. 07. Heated bed, Heated bed assembly - MK2.5(S): step 9, image 1 of 2 07. Heated bed, Heated bed assembly - MK2.5(S): step 9, image 2 of 2
      • Remove the two temporary hex nuts from the Y carriage. Keep the M3x12 screws of the y_belt_holder in place.
      Ask FixBot
    10. 07. Heated bed, Heated bed assembly - MK2.5(S): step 10, image 1 of 3 07. Heated bed, Heated bed assembly - MK2.5(S): step 10, image 2 of 3 07. Heated bed, Heated bed assembly - MK2.5(S): step 10, image 3 of 3
      Ask FixBot
    11. 07. Heated bed, Heat bed cable check - MK2.5(S): step 11, image 1 of 1
      Ask FixBot
    12. 07. Heated bed, Next chapter: step 12, image 1 of 1
      Ask FixBot
    13. 07. Heated bed, Heated bed type: step 13, image 1 of 1
      • The next steps are for MK3(S) heated bed only.
      • Prusa MK3(S): continue to the next step.
      Ask FixBot
    14. 07. Heated bed, Heat bed cable check - MK3(S): step 14, image 1 of 2 07. Heated bed, Heat bed cable check - MK3(S): step 14, image 2 of 2
      Ask FixBot
    15. 07. Heated bed, Prepare heated bed assembly - MK3(S): step 15, image 1 of 3 07. Heated bed, Prepare heated bed assembly - MK3(S): step 15, image 2 of 3 07. Heated bed, Prepare heated bed assembly - MK3(S): step 15, image 3 of 3
      • Prepare the following hardware:
      • 9x M3x12 or M3x14 flat head screws (reused from your Original Prusa).
      • 9x spacers 5.5x6x3 (reused from your Original Prusa).
      • 1x 2mm Allen key.
      • Move the Y carriage to the front.
      • Locate the center hole of the Y carriage.
      • Place 1x spacer on the hole of the Y carriage.
      Ask FixBot
    16. 07. Heated bed, Heated bed assembly - MK3(S): step 16, image 1 of 3 07. Heated bed, Heated bed assembly - MK3(S): step 16, image 2 of 3 07. Heated bed, Heated bed assembly - MK3(S): step 16, image 3 of 3
      • Take your heated bed and insert the hex key in the centeral hole.
      • Place the heated bed with the hex key on the Y carriage. Align the bed with the spacer and the centeral hole of the Y carriage using the hex key.
      • Add one of the M3 flat head screws and secure the bed in the centre. Do not fully tighten the screw yet.
      Ask FixBot
    17. 07. Heated bed, Heated bed assembly - MK3(S): step 17, image 1 of 3 07. Heated bed, Heated bed assembly - MK3(S): step 17, image 2 of 3 07. Heated bed, Heated bed assembly - MK3(S): step 17, image 3 of 3
      • From the right of the bed (or left if you are left-handed), insert a second spacer between the Y carriage and the heated bed. Use needle nosed pliers to make the insertion easier.
      • Use the 2mm hex key to align the spacer.
      • Secure the bed and spacer using one of the M3 flat head screws. Do not tighten fully yet.
      Ask FixBot
    18. 07. Heated bed, Heated bed assembly - MK3(S): step 18, image 1 of 2 07. Heated bed, Heated bed assembly - MK3(S): step 18, image 2 of 2
      • Continue with the 7 other points of the heated bed.
      • Make sure no screw is fully tightened or you may warp the heated bed.
      • Fully tighten the M3 flat head screws evenly and incrementally in this precise order:
      • 1st center screw.
      • 2nd corner screws.
      • 3rd side screws.
      Ask FixBot
    19. 07. Heated bed, Heat bed cable check - MK3(S): step 19, image 1 of 1
      • Verify again that the thermistor cable is not stretched (it should make a small curve) and does not sag down too much as it could be damaged with bed movements.
      Ask FixBot
    20. 07. Heated bed, Next chapter: step 20, image 1 of 1
      Ask FixBot
Finish Line
Greg Bear
8,773 Reputation
35 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 107
All Time: 107
