Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Models
A3473 US, A3716 CA.MX/JP/SA, A3717 Global, A3718 China
Background
The iPhone 18 Pro Max was announced on September 9th, 2026 alongside the iPhone Duo and iPhone 18 Pro. It's an iteration over the 17 Pro Max, featuring the same large aluminum unibody coupled with a glass pane underneath the large camera plateau. Just like the last three generations, it has an Action button above the volume buttons and a Camera Control button on the right edge.
The vapor chamber, new for last year, has improved, offering better cooling and 3x the surface area for the new and completely redesigned A20 Pro chip. The screen size remains the same as the previous generation at 6.9 inches.
The rear main 48 MP Fusion camera now features variable aperture and software-adjustable shutter speed. Other improvements include better battery life, faster wired charging, and a smaller Dynamic Island.
The iPhone 18 Pro is available in Burgundy, Glacier, Silver, and Black and starts at $1,299.
Identification
You can identify the iPhone 18 Pro Max by the model number printed inside of the USB-C charge port.
  • A3473
  • A3717
You can also find the model number through the phone's UI by going to the Settings app and navigating to General > About. Tap on the number listed in the Model Number section and it should change to a format that looks like the numbers above.
Additionally, Apple offers a quick online tool to help identify your devices: Identify your iPhone model.
The iPhone 18 Pro Max features a 6.9-inch (diagonal) flat glass screen, thin black bezels, a pill-shaped, black "dynamic island" at the top of the screen, matte back glass with a glossy Apple logo, and aluminum side rails. Its camera "plateau" also reaches across the top left and top right edges of the backside of the phone. The 18 Pro Max has a small cutout for the Ceramic Shield glass pane underneath the rear cameras.
Volume controls and the Action Button can be found on the left edge, while the power button and Camera Control button are situated on the right. Three cameras protrude from the backside. This model has no home button.
The iPhone 18 Pro Max can be differentiated from the iPhone 18 Pro by its larger screen (relative to the 6.3-inch screen on the Pro model).
The iPhone 18 Pro Max can be differentiated from the previous generation iPhone 17 Pro Max by the color matched rear glass panel and smaller Dynamic Island.
Technical Specifications
Dimensions: 163.4 × 78.0 × 8.75 mm (6.43 × 3.07 × 0.34 in)
Weight: 249 g (8.78 oz)
Water Resistance: IP68 (maximum depth of 6 meters up to 30 minutes)
Colors: Burgundy, Glacier, Silver, and Black
Operating System: iOS 27
Processor: A20 Pro chip
  • 6‑core CPU with 2 super and 4 efficiency cores
  • 7‑core GPU with Neural Accelerators
  • Dual 16‑core Neural Engines
  • Hardware‑accelerated ray tracing
RAM: 12 GB LPDDR5X
Storage: 256 GB, 512 GB, 1 TB, or 2 TB
Battery: 5,391 mAh li-ion
  • Up to 45 hours of video playback
  • Wired charging up to ~60 W
  • MagSafe and Qi2 wireless charging up to 25 W
Ports: 1x USB-C connector
  • Reverse charging of accessories
  • DisplayPort
  • USB 3 data transfer (up to 10 Gb/s)
Display:
  • 6.9-inch “Super Retina XDR” OLED
  • Ceramic Shield 2 glass technology
  • Multi‑touch
  • Haptic Touch
  • 2868 × 1320 pixel resolution (460 ppi)
  • ProMotion adaptive refresh rate (1-120 Hz)
  • 2,000,000:1 contrast ratio (typical)
  • True Tone
  • P3 wide color gamut
  • 1000 nits max brightness, 1600 nits peak (HDR), 3000 nits peak (outdoor), 1 nit minimum
  • Fingerprint-resistant oleophobic coating
  • Dynamic Island
  • Anti-Reflective Coating
Pro camera system:
  • Main module
    • 48 MP "Pro Fusion"
    • 24 mm, ƒ/1.48–4.0 variable aperture
    • Sensor-shift optical image stabilization (OIS)
    • Autofocus with 100% Focus Pixels
    • Enables 12 MP 2x optical-quality zoom
    • 4K120 video recording
  • Ultra-wide module
    • 48 MP "Fusion"
    • 13 mm, ƒ/2.2 aperture
    • Autofocus with Hybrid Focus Pixels
    • 120° field of view
  • Telephoto module
    • 48 MP "Fusion"
    • 100 mm (4x), ƒ/2.8 aperture
    • 3D sensor-shift optical image stabilization (OIS)
    • Enables 12 MP 8x optical-quality zoom
    • "Tetraprism" design
"Center Stage" selfie camera with Face ID:
  • 18 MP
  • ƒ/1.9 aperture
  • 4K60 video recording
  • Retina Flash
  • Ultra-stabilized video
  • Smart HDR 5
  • Dual Capture
  • 4K Dolby Vision video recording at 24 fps, 25 fps, 30 fps, or 60 fps
  • 1080p Dolby Vision video recording at 25 fps, 30 fps, or 60 fps
  • Cinematic mode up to 4K Dolby Vision at 30 fps
  • Slo-mo video support for 1080p at 120 fps
  • Time‑lapse video with stabilization
Sensors:
  • Face ID
  • LiDAR scanner
  • Barometer
  • High dynamic range gyro
  • High-G accelerometer (Crash Detection)
  • Proximity sensor
  • Dual ambient light sensors
Wireless Connectivity:
  • Apple N1 wireless networking chip
  • 802.11be Wi‑Fi 7 with 2x2 MIMO
  • 5G, sub-6 GHz and mmWave (all models)
  • Gigabit LTE with 4x4 MIMO and LAA (all models)
  • Bluetooth 6
  • Second-generation Ultra Wideband chip
  • Thread networking technology
  • NFC with reader mode
  • Express Cards with power reserve
Additional Information
Manuals and Support
Author
with
Carsten Frauenheim
174,985 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 250
Past 7 Days: 1,593
Past 30 Days: 7,299
All Time: 25,347
