Up to 20% off select tools
Models
A3575 US/CA/MX/JP/SA, A3634 Global, A3635 China
Background
The iPhone 17e was announced via press release on March 2nd, 2026. The fifth affordable "SE family" smartphone from Apple, the iPhone 17e is the direct successor to 2024's iPhone 16e, and is mostly a simplified version of the iPhone 17, sporting a single 48 MP 2-in-1 camera module (no ultrawide), USB-C charging, an Action button, the 6.1-inch OLED display from the iPhone 14, a notch instead of a Dynamic Island "pill," and a binned-down A19 SoC.
Previously removed from the 16e, the 17e now brings back MagSafe. The base storage is now also doubled, from 128 to 256 GB, and features Ceramic Shield 2. The 17e is 2g heavier than the 16e, but has otherwise identical dimensions.
The iPhone 17e uses the Apple C1X modem that debuted in the iPhone Air, and retains USB 2.0 data speed.
The iPhone 17e has the same starting price as the 16e at $599, and is available in 256 or 512 GB configurations. It has an aluminum construction and comes in either Black, White, or a new matte Soft Pink colorway.
Identification
You can identify the iPhone 17e by the model number printed inside of the USB-C charge port.
You can also find the model number through the phone's UI by going to the Settings app and navigating to General > About. Tap on the number listed in the Model Number section and it should change to a format that looks like the numbers above.
Additionally, Apple offers a quick online tool to help identify your devices: Identify your iPhone model.
The iPhone 17e features a 6.1-inch (diagonal) flat glass screen, thin black bezels, a black notch at the top of the screen, matte back glass, and aluminum side rails.
Volume controls and the Action Button can be found on the left edge, while the power button is situated on the right. A single camera lens protrudes from the back case. This model has no home button.
The iPhone 17e can be differentiated from the iPhone 17 by its display notch and single camera system (relative to the Dynamic Island and dual camera system on the 17).
Technical Specifications
Dimensions: 146.7 x 71.5 x 7.80 mm (5.78 x 2.82 x 0.31 in)
Weight: 169 g (5.96 oz)
Water Resistance: IP68
Colors: Black, White, Soft Pink
Operating System: iOS 26
Processor: A19 Chip
  • 6‑core CPU with 2 performance and 4 efficiency cores
  • 4‑core GPU
  • 16‑core Neural Engine
Storage: 256 or 512 GB
Battery: Up to 26 hours of video playback
Ports: 1x USB-C connector
  • Charging
  • DisplayPort
  • USB 2.0 (up to 480Mb/s)
Display:
  • 6.1-inch “Super Retina XDR” OLED
  • Ceramic Shield 2 glass technology
  • Multi‑touch
  • Haptic Touch
  • 2532 × 1170 pixel resolution (460 ppi)
  • 2,000,000:1 contrast ratio (typical)
  • True Tone
  • P3 wide color gamut
  • 800 nits max brightness, 1200 nits peak (HDR)
  • Fingerprint-resistant oleophobic coating
"2-in-1" camera system:
  • 48 MP "Fusion"
  • 26 mm, ƒ/1.6 aperture
  • Optical image stabilization (OIS)
  • Auto image stabilization
  • Enables 12 MP 2x optical telephoto
  • 4K60 video recording
TrueDepth selfie camera with Face ID:
  • 12 MP
  • ƒ/1.9 aperture
  • Autofocus with Focus Pixels
Sensors:
  • Face ID
  • Barometer
  • High dynamic range gyro
  • High-G accelerometer (Crash Detection)
  • Proximity sensor
  • Dual ambient light sensors
Wireless Connectivity:
  • 802.11ax Wi‑Fi 6 with 2x2 MIMO
  • 5G, sub-6 GHz with 4x4 MIMO
  • Gigabit LTE with 4x4 MIMO
  • Bluetooth 5.3
  • NFC with reader mode
  • Express Cards with power reserve
Additional Information
Carsten Frauenheim
174,979 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 47
Past 7 Days: 343
Past 30 Days: 1,543
All Time: 41,479
