Battery
2 Answers 2 Score |
iPhone 14 Plus Panic Full - SMC BSC failure 0x500000 |
6 Answers 4 Score |
Panic full error code 0x500000 |
6 Answers 1 Score |
My microphone is not working |
1 Answer 1 Score |
My power button is not working. |
Documents
Parts
- iPhone 14 Plus Battery
- iPhone 14 Plus Screen
- iPhone 14 Plus Rear Panel Adhesive
- iPhone 14 Plus Rear Camera Assembly
- Grip Glass Ultra iPhone 13 Pro Max and 14 Plus Screen Protector
- iPhone 14 Plus Display Assembly Adhesive
- iPhone 14/14 Plus Rear Camera Lenses and Bezels
- Lightning to USB Charging Cable
Tools
- Spudger
- iOpener
- iFixit Opening Picks (Set of 6)
- Tweezers
- Suction Handle
- Phillips #00 Screwdriver
- Heat Gun
- iFixit Safety Glasses
- P2 Pentalobe Screwdriver iPhone
- Tri-point Y000 Screwdriver
- Standoff Screwdriver for iPhones
- SIM Card Eject Tool
- iHold EVO
- IA-3952 - Max Professional Consumable Isopropyl Alcohol
Models
A2632 US, A2885 Canada/Mexico/Japan/Saudi Arabia, A2886 Global, A2887 Russia, A2888 China
Background
The iPhone 14 Plus was announced on September 7th, 2022 alongside its brothers and sister of that series. It was released on October 7th.
It features Apple’s 2021 processing, namely the A15 Bionic chip but with an extra GPU core and the same display notch as the 2021 models and its smaller sibling the iPhone 14.
Identification
You can identify the iPhone 14 Plus by the one of the following model numbers printed on the inside back of the Lightning (charge) port. Flip the iPhone over (with the screen facing away from you) to see it.
- A2632
- A2885
- A2886
- A2887
- A2888
You can also find the model number through the phone's UI by going to the Settings app and navigating to General > About. Tap on the number listed in the Model Number section and it should change to a format that looks like the numbers above.
The iPhone 14 Plus features a 6.7 in (diagonal) flat glass screen, thin black bezels, and a notch at the top of the screen to accommodate a speaker and selfie camera. The back cover is glass and the edge frame is made from flat anodized aluminum.
Volume controls can be found on the left edge while the power button is situated on the right. A rectangular camera "bump" containing two diagonally-aligned cameras protrudes slightly from the back case. This model has no home button.
Technical Specifications
Dimensions: 160.8 x 78.1 x 7.8 mm (6.33 x 3.07 x 0.31 in)
Weight: 203 g (7.16 oz)
Water Resistance: IP68
Colors: Midnight, Purple, Starlight, (PRODUCT)RED, or Blue
Operating System: iOS 16
Processor: A15 Bionic chip (2022 edition)
- 6‑core CPU with 2 performance and 4 efficiency cores
- 5‑core GPU
- 16‑core Neural Engine
RAM: 6 GB
Storage: 128, 256, 512 GB, or 1 TB
Display:
- 6.7-inch “Super Retina XDR” OLED
- Ceramic Shield glass technology
- Multi‑touch
- Haptic Touch
- 2778 × 1284 pixel resolution (458 ppi)
- 2,000,000:1 contrast ratio (typical)
- True Tone
- P3 wide color gamut
- 800 nits max brightness, 1200 nits peak (HDR)
- Fingerprint-resistant oleophobic coating
Dual camera system:
- Main module
- 12 MP
- ƒ/1.5 aperture
- Sensor-shift optical image stabilization (OIS)
- Autofocus with 100% Focus Pixels
- Seven-element lens
- Ultra-wide module (120° field of view, 2x optical zoom)
- 12 MP
- ƒ/2.4 aperture
- Six-element lens
TrueDepth selfie camera with Face ID:
- 12 MP
- ƒ/1.9 aperture
- HDR video up to 4K at 60 fps
- Six‑element lens
- Retina Flash
Sensors:
- Face ID
- Barometer
- High dynamic range gyro
- High-g accelerometer (Crash Detection)
- Proximity sensor
- Dual Ambient light sensor
Wireless Connectivity:
- 802.11ax Wi‑Fi 6 with 2x2 MIMO
- 5G (sub-6 GHz in all models, mmWave only US-model)
- Gigabit LTE with 4x4 MIMO (LAA only US-model)
- Bluetooth 5.3
- Apple-designed U1 Ultra Wideband chip for spatial awareness
- NFC with reader mode
- Express Cards with power reserve
Additional Information
- Official Apple page: iPhone 14 Plus
- Apple: iPhone 14 Plus repair manual
