Battery
3 Answers 0 Score |
How to remove round camera lens protector |
4 Answers 2 Score |
Guide for replacing lightning port |
1 Answer 2 Score |
iPhone 12 pro max no WiFi, Bluetooth, or cellular data |
3 Answers 6 Score |
Would replacing the motherboard have any issues? |
Documents
Parts
- iPhone 12 Pro Max Battery
- iPhone 12 Pro Max Screen
- iPhone 12 Pro Max Loudspeaker
- iPhone 12 Pro Max Display Assembly Adhesive
- iPhone 12 Pro Max Earpiece Speaker and Sensor Assembly
- iPhone 12 Pro Max Rear Camera Lens Covers
- NuGlas Tempered Glass Screen Protector for iPhone 12 Pro Max
- iPhone 12 Pro Max Lightning Connector Assembly
Tools
- Clampy - Anti-Clamp
- Spudger
- iOpener
- iFixit Opening Picks (Set of 6)
- Tweezers
- Suction Handle
- Phillips #00 Screwdriver
- Heat Gun
- P2 Pentalobe Screwdriver iPhone
- Tri-point Y000 Screwdriver
- Standoff Screwdriver for iPhones
- SIM Card Eject Tool
- iHold EVO
- IA-3952 - Max Professional Consumable Isopropyl Alcohol
Models
A2342 US, A2410 Canada/Japan, A2411 Global, A2412 China
Wallpapers
Want a phone teardown right in the palm of your hand? Check out our free iPhone 12 Pro Max teardown wallpapers! Choose from iFixit or Creative Electron (X-ray) versions.
Background and Identification
The iPhone 12 Pro Max was released on November 13th, 2020 starting at $1,099 USD, the same price as the iPhone 11 Pro Max before it, but the base configuration now grants 128 GB of storage: double the capacity of the previous base model. It also features an upsized 6.7” Super Retina XDR OLED display with an upgraded resolution versus the 6.5” display in the iPhone 11 Pro Max. All four iPhones in Apple’s 2020 lineup dropped their curved edges in favor of a flat stainless steel form-factor and add 5G connectivity and a new MagSafe charging system. For the first time, Apple opted not to include a power adapter or EarPods in the box for any of the iPhone 12 series—only a Lightning to USB-C cable. The iPhone 12 Pro Max is offered in updated versions of the classic Gold and Silver color options, as well as Graphite and Pacific Blue.
The most often replaced iPhone 12 Pro Max parts include the battery, screen, speakers, and lenses.
Identification
You can identify the iPhone 12 Pro Max by finding one of the model numbers either on the inner edge of the SIM card tray or within the phone's Settings app:
- A2342
- A2410
- A2412
- A2411
You can find the model number through the phone's UI by going to the Settings app and navigating to General > About. Tap on the number listed in the Model Number section and it should change to a format that looks like the numbers above.
The iPhone 12 Pro features a 6.7 in (diagonal) flat glass screen, thin black bezels, and a notch at the top of the screen to accommodate a speaker and selfie camera. The back cover is glass and the edge frame is made from flat stainless steel.
Volume controls and the SIM tray can be found on the left edge while the power button is situated on the right. A rectangular camera "bump" containing three cameras in a triagonal layout protrudes slightly from the back case. This model has no home button.
The iPhone 12 Pro Max can be differentiated from the iPhone 12 Pro by the 6.7 in screen (relative to the 6.1 in screen on the standard Pro model).
Specifications
Announce date: October 13, 2020
Operating System: iOS 14
Display:
- 6.7-inch “Super Retina XDR” OLED display
- Ceramic Shield glass technology
- Multi‑touch
- Haptic Touch
- 2778 × 1284 pixel resolution (458 PPI)
- 2,000,000:1 contrast ratio (typical)
- True Tone
- P3 wide color gamut
- 800 nits max brightness; 1200 nits max HDR (typical)
- Fingerprint-resistant oleophobic coating
Triple primary camera:
- True Tone flash
- LiDAR scanner
- Apple ProRAW
- 4K 10-bit HDR video recording with Dolby Vision HDR, up to 60 fps
- 5x optical zoom range
- Wide-angle module
- 12 MP
- ƒ/1.6 aperture
- Sensor-shift optical image stabilization (OIS)
- Autofocus with 100% Focus Pixels
- Seven-element lens
- Ultra-wide module (120° field of view, 2x optical zoom out)
- 12 MP
- ƒ/2.4 aperture
- Five-element lens
- Telephoto module (2.5x optical zoom in)
- 12 MP
- ƒ/2.2 aperture
- Optical image stabilization (OIS)
- Six-element lens
- 65-mm equivalent
TrueDepth selfie camera with Face ID:
- 12 MP
- ƒ/2.2 aperture
- 4K video recording, up to 60 fps
- Retina Flash
Processor: A14 Bionic with Neural Engine
- 5 nm process
- 6-core CPU
- 4-core GPU
RAM: 6 GB
Storage: 128, 256, or 512 GB
Sensors:
- Face ID
- Compass
- Barometer
- Three-axis gyro
- Accelerometer
- Proximity sensor
- Ambient light sensor
Wireless Connectivity:
- 802.11ax Wi‑Fi 6 with 2x2 MIMO
- 5G (sub-6 GHz and mmWave)
- Gigabit LTE with 4x4 MIMO and LAA
- Bluetooth 5.0
- Apple-designed U1 Ultra Wideband chip for spatial awareness
- NFC
Dimensions: 6.33 × 3.07 × 0.29 in (160.8 × 78.1 × 7.4 mm)
Weight: 226 g (7.97 oz), 228 g (8.03 oz) mmWave model
Water Resistance: IP68
Colors: Silver, Graphite, Gold, Pacific Blue
