Up to 20% off select tools
Guides
Models
A2925 Wi-Fi (2024), A2926 Wi-Fi/Cellular Global (2024), A3007 Wi-Fi/Cellular China (2024)
Background Information
Announced the morning of May 7th, 2024, Apple's "large" iPad Pro has been refreshed for the first time since 2018 alongside the new 5th generation 11-inch model. Now marketed as 13" instead of 12.9", the 7th generation features a new Ultra Retina XDR display with "tandem OLED" technology, M4 SoC, and supports the Apple Pencil Pro. The front-facing camera has been moved to the long edge for landscape use and the base storage has increased from 128 to 256 GB.
The 5th generation 11-inch iPad Pro and new 13-inch iPad Pro are Apple’s first devices to use the M4 chip.
At 5.1 mm thick, the 13-inch iPad Pro is the thinnest Apple product ever (besides the Polishing Cloth), beating out the 5.4 mm-thick iPod nano (7th generation) from 2012.
The 13-inch iPad Pro starts at $1299 and is available in Silver or Space Black.
Identification
The 7th generation 13-inch iPad Pro is thinner than the outgoing model. The aluminum back case extends over the camera bump, which is rectangular and contains a single rear camera and LiDAR sensor. The charging port is USB Type‑C.
iPad model numbers are etched into the back case. Look here to follow Apple's instructions to identify your iPad model.
Technical Specifications
Display:
  • 13-inch, 2752 x 2064 (264 ppi) Ultra Retina XDR Tandem OLED display
  • 10–120 Hz ProMotion dynamic refresh rate
  • P3 color gamut, 2,000,000:1 contrast ratio
  • 1000 nits max SDR brightness, 1600 nits peak HDR brightness
Chip:
  • M4 SoC, 9-core CPU, 10-core GPU, 16-core Neural Engine
  • Configurable to 10-core CPU
Memory:
  • 8 GB, configurable to 16 GB (both 120 GB/s bandwidth)
Storage:
  • 256 GB, configurable to 512 GB, 1 TB, and 2 TB
Battery:
  • 38.99 Wh Li-Po
Cameras:
  • Rear-facing 12 MP Wide, ƒ/1.8 aperture, 5-element lens
    • 4K video recording up to 60 fps
    • Slo-mo video recording up to 1080p 240 fps
    • Adaptive True Tone flash
  • Front-facing 12 MP TrueDepth with Center Stage, ƒ/2 aperture
    • 1080p video recording up to 60 fps
    • Portrait mode with depth control
Sensors:
  • Face ID
  • Ambient light sensors
  • LiDAR Scanner
Connectivity:
  • Thunderbolt 4 / USB 4 USB‑C port (up to 40 GB/s)
  • Smart Connector (for keyboards and accessories)
  • Magnetic connector (for Apple Pencil)
  • Wi-Fi 6E (802.11ax) with 2x2 MIMO
  • Bluetooth 5.3
  • Cellular models: 5G sub-6 GHz with 4x4 MIMO, eSIM
Dimensions and Weight:
  • 11.09 x 8.48 x 0.20 inches (281.6 x 215.5 x 5.1 mm)
  • 1.28 lbs (582 g)
Additional Information
Author
with
Carsten Frauenheim
174,985 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 12
Past 7 Days: 158
Past 30 Days: 714
All Time: 21,501
