Up to 20% off select tools
Guides
Documents
Background and Identification
The Yocan UNI Pro is a weed pen, also known as a vape pen, which is a small portable device used to inhale cannabis oil or other forms of THC (tetrahydrocannabinol) or CBD (cannabidiol) concentrates. They typically consist of a battery and a heating element, which vaporizes the oil or concentrates, allowing the user to inhale the vapor. They are often used as an alternative to smoking.
Yocan released the Yocan UNI Pro in September 2019 for $39. It is a compact and portable device equipped with various features, such as adjustable voltage, adjustable height, and a preheat function. The device uses a magnetic 510-threaded connection, which makes it compatible with a wide range of cartridges. It also has a built-in micro USB port for easy recharging and a battery size of 650mAh.
Specifications
Height: 75.5 mm
Width: 36.5 mm
Depth: 25.7 mm
Weight: 51g
Voltage Range: 2.0V to 4.2V.
Battery Size: 650mAh
Colors: Black, White, Apple Green, Purple, Dark Champagne, Dark Blue, Green, Rosy Silver, Airy Blue, Red, Black Green Spatter, Black Red Spatter, Black White Spatter, Purple Black Spatter, Pink Black Spatter, Teal Black Spatter, White Black Spatter, White Red Spatter, Rainbow
Additional Information
Author
with
ShellingRook27
2,383 Reputation
7 Guides authored
Repair For You Member of Repair For You
Business
1 Member
84 Guides authored
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 99
All Time: 5,849
