Up to 20% off select tools
Yocan UNI Pro Disassembly
Views: 16K
View statistics:
Past 24 Hours:
9
Past 7 Days:
78
Past 30 Days:
305
All Time:
15,566
Comments: 12
2 comments on steps, 10 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
My device was water damaged so I decided to take it apart! You will see signs of corrosion on the motherboard and electronics closeup images.
    1. Yocan UNI Pro Disassembly, Outer Screws: step 1, image 1 of 3 Yocan UNI Pro Disassembly, Outer Screws: step 1, image 2 of 3 Yocan UNI Pro Disassembly, Outer Screws: step 1, image 3 of 3
      • Remove 2 Phillips head screws. There is one on each side of the device
      Ask FixBot
    2. Yocan UNI Pro Disassembly, Housing Removal: step 2, image 1 of 3 Yocan UNI Pro Disassembly, Housing Removal: step 2, image 2 of 3 Yocan UNI Pro Disassembly, Housing Removal: step 2, image 3 of 3
      • Flip the device over and pull the cover upwards
      Ask FixBot
    3. Yocan UNI Pro Disassembly, Aperture Removal: step 3, image 1 of 3 Yocan UNI Pro Disassembly, Aperture Removal: step 3, image 2 of 3 Yocan UNI Pro Disassembly, Aperture Removal: step 3, image 3 of 3
      • Remove the aperture adjustment holder
      Ask FixBot
    4. Yocan UNI Pro Disassembly, O-Ring: step 4, image 1 of 2 Yocan UNI Pro Disassembly, O-Ring: step 4, image 2 of 2
      • Remove O-Ring
      Ask FixBot
    5. Yocan UNI Pro Disassembly, Buttons and Shutter Pieces: step 5, image 1 of 2 Yocan UNI Pro Disassembly, Buttons and Shutter Pieces: step 5, image 2 of 2
      • Remove buttons and aperture/shutter pieces
      • They should just fall out. If not, they can be removed with your fingers
      Ask FixBot
    6. Yocan UNI Pro Disassembly, Inner Plasic: step 6, image 1 of 2 Yocan UNI Pro Disassembly, Inner Plasic: step 6, image 2 of 2
      • Grip the bottom and top of the device and pull up slightly
      • The next step will fully remove it
      Ask FixBot
    7. Yocan UNI Pro Disassembly, Full Electronics Removal: step 7, image 1 of 3 Yocan UNI Pro Disassembly, Full Electronics Removal: step 7, image 2 of 3 Yocan UNI Pro Disassembly, Full Electronics Removal: step 7, image 3 of 3
      • Pull the clear plastic out and away to the left
      • Pull up at an angle
      Ask FixBot
    8. Yocan UNI Pro Disassembly, Kapton Tape Removal: step 8, image 1 of 3 Yocan UNI Pro Disassembly, Kapton Tape Removal: step 8, image 2 of 3 Yocan UNI Pro Disassembly, Kapton Tape Removal: step 8, image 3 of 3
      • Peel the Kapton Tape off of the battery and clear plastic
      Ask FixBot
    9. Yocan UNI Pro Disassembly, PCB Slide Out: step 9, image 1 of 2 Yocan UNI Pro Disassembly, PCB Slide Out: step 9, image 2 of 2
      • Slide the circuit board back so that it is not under the plastic lip
      Ask FixBot
    10. Yocan UNI Pro Disassembly, Battery Adhesive Removal: step 10, image 1 of 3 Yocan UNI Pro Disassembly, Battery Adhesive Removal: step 10, image 2 of 3 Yocan UNI Pro Disassembly, Battery Adhesive Removal: step 10, image 3 of 3
      • Slowly peel the battery and circuit board away from the plastic housing
      • There is some adhesive under the battery so be careful
      Ask FixBot
    11. Yocan UNI Pro Disassembly, Height Adjustment Module: step 11, image 1 of 3 Yocan UNI Pro Disassembly, Height Adjustment Module: step 11, image 2 of 3 Yocan UNI Pro Disassembly, Height Adjustment Module: step 11, image 3 of 3
      • Grip the plastic case and use your thumb to remove the height adjustment module
      • It should slide out all the way
      • The ball bearings in the next step might fall out right away so be careful that they don't roll away!
      Ask FixBot
    12. Yocan UNI Pro Disassembly, Ball Bearings: step 12, image 1 of 3 Yocan UNI Pro Disassembly, Ball Bearings: step 12, image 2 of 3 Yocan UNI Pro Disassembly, Ball Bearings: step 12, image 3 of 3
      • There are two ball bearings that make the height adjustment module work and lock into position.
      • There is one on each side and they easily fall out so be careful
      Ask FixBot
    13. Yocan UNI Pro Disassembly, Motherboard and Battery Closeup: step 13, image 1 of 2 Yocan UNI Pro Disassembly, Motherboard and Battery Closeup: step 13, image 2 of 2
      • Just some pretty pictures
      Ask FixBot
    14. Yocan UNI Pro Disassembly, Screen Removal: step 14, image 1 of 3 Yocan UNI Pro Disassembly, Screen Removal: step 14, image 2 of 3 Yocan UNI Pro Disassembly, Screen Removal: step 14, image 3 of 3
      • Use a spudger to carefully remove the screen
      • It is held down with adhesive
      • There is no way to remove the screen completely unless you get rid of the red strain relief material and desolder it from the board
      Ask FixBot
    15. Yocan UNI Pro Disassembly, Shutter Reassembly: step 15, image 1 of 3 Yocan UNI Pro Disassembly, Shutter Reassembly: step 15, image 2 of 3 Yocan UNI Pro Disassembly, Shutter Reassembly: step 15, image 3 of 3
      • For reassembly, place the slots on the small shutter pieces into the circular holder
      Ask FixBot
10 other people completed this guide.
Author
with
ShellingRook27
2,383 Reputation
7 Guides authored
Repair For You Member of Repair For You
Business
1 Member
84 Guides authored
10 Guide Comments
I got a cartridge stuck in mine... avoid the 2 gram DOZOs, they're so poorly made that just putting it in you can't get it out normally!
Joe Drew - Reply Share
I somehow managed to get a single hair under the casing and over the screen on my Yocan Uni Pro. With the help of this guide, I was able to disassemble, clean, and re-assemble my vape quickly and easily - I'm especially grateful for the pictures showing how to disassemble/reassemble the shutter pieces. Thank you so much for this awesome guide!
Amy Kaufman - Reply Share
Thank you! Needed to clean my device and man oh man was I struggling with the shutter reassembly! Thanks so much for the time and effort for this guide, seriously helpful!
BingBong - Reply Share
While reassembling my 2.0 I accidentally touched the front metal shield to the “C1” on the circuit board and shorted it. Whole battery is cooked. Oops. Don’t make my mistake.
Will - Reply Share
This post literally saved me from buying a new battery. The slider was virtually glued to the case and seized up, and I had to push the cart at an angle just to get it to work and I could not figure out how to get it clean. Now it’s clean fully functional again!
Having access to a computer repair toolkit helped make quick work with these instructions but honestly anyone could probably follow these with a small eye glass screwdriver (and some rubbing alcohol and towels) to do the job, with maybe some sturdy tooth picks for the crevices
Kenneth Robinson - Reply Share
Past 24 Hours: 9
Past 7 Days: 78
Past 30 Days: 305
All Time: 15,566
