Up to 20% off select tools
Guides
6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
VP1430AW/AH
Background and Identification
This machine is part of the VP series, which stands for vibratory plate. It is intended for use in compacting asphalt and soil for construction of paths and other landscaping needs. The smaller size of this machine makes it easier to maneuver around obstacles and operate in smaller spaces. The AW variation of this machine uses a water tank with 9 L capacity, which can be used to wet the compacted material as the machine works.
Plate compactors are commonly used in construction work for packing down and solidifying foundations and creating level grades. The vibration that they produce comes from rapidly rotating a centrifuge inside the machine. This type of compactor is commonly called a ‘wacker.’ This nickname actually comes from the Wacker Neuson company, which designed this compactor and is very well-known for selling plate compactors and other equipment.
Technical Specifications
  • Weight: 178.6 lbs
  • Centrifugal force: 2,922,52 lbf
  • Base plate size (w x l): 15.9 x 23.5 in
  • Operating width: 15.9 in
  • Operating height: 25.2 in
  • Frequency: 98 Hz
  • Surface capacity: 6,458 ft²/h
  • Engine: Honda GX160UT2
  • Engine: 4-stroke gasoline
  • Displacement: 9.9 in³
  • Performance: 3.6 kW at 3,600 rpm
  • Fuel consumption: 0.2 gal/h
  • Fuel tank capacity: 0.94 gal
Additional Information
Full List of Technical Specifications (Metric or Imperial)
Product Page
Plate Compactor - Wikipedia
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 16
Past 7 Days: 114
Past 30 Days: 655
All Time: 36,876
