Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
Device Name: UP! Plus 2
Release Date: June 1st, 2013
This particular 3D printer was the first to offer automatic bed leveling and automatic height adjustments, making it one of the easiest 3D printers to use on the market to date.
The earliest revisions of the printer came with optical height detection switches for the auto-leveling process, which were later replaced by the more precise mechanical switches. However, the version with the height detection switch will not affect your repairs, as the switch is an external part that is only used during the auto-leveling process.
Identification
You can identify your UP! Plus 2 by the model, 3DP-14-4D, and serial numbers printed on a label located on the back of the 3D printer. This model has an off-white, metal body with a black printing platform in the front and the spool holder on the side of the device. The web address PP3DP.com is stamped on the side of the print head cover.
Specifications
Model Number: 3DP-14-4D
Printer Size: 245mm Wide x 260mm Deep x 350mm High (9.5 x 10.5 x 14 inch)
Weight: 5 Kg (11 lbs)
Supported Operating Systems: Windows XP, Windows Vista, Windows 7, Mac
Build Size: 140mm Wide x 140mm Deep x 135mm High (5.5 x 5.5 x 5.3 inch)
Build Material: ABS and PLA Plastic
Layer Thickness: Variable between 0.15/0.20 /0.25 /0.30 /0.35 /0.40 mm
Additional Information
Buy Used on Amazon
Community Support Forum for UP Brand Printers
UP! Plus 2 User Manual
Up! Plus 2 Product information
UP! Plus 2 Review and Features
UP Plus 2 クイックスタートガイド
Author
with
Spencer Jefferson
106 Reputation
0 Guides authored
Cal Poly, Team 14-31, Maness Fall 2014 Member of Cal Poly, Team 14-31, Maness Fall 2014
CPSU-MANESS-F14S14G31
4 Members
60 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 32
All Time: 4,378
