UP! Plus 2 Extrusion Head Fan Replacement
    1. UP! Plus 2 Extrusion Head Fan Replacement, Remove fan cover: step 1, image 1 of 2 UP! Plus 2 Extrusion Head Fan Replacement, Remove fan cover: step 1, image 2 of 2
      • Remove the plastic cover that sits on the extruder, next to the fan, by lifting the latches in the back. The latches should lift right out.
      Ask FixBot
    2. UP! Plus 2 Extrusion Head Fan Replacement, Remove fan: step 2, image 1 of 2 UP! Plus 2 Extrusion Head Fan Replacement, Remove fan: step 2, image 2 of 2
      • Using the Phillips #0 screwdriver, locate and remove the two 3mm screws on the top of the fan using a counter-clockwise rotation.
      Ask FixBot
    3. UP! Plus 2 Extrusion Head Fan Replacement: step 3, image 1 of 2 UP! Plus 2 Extrusion Head Fan Replacement: step 3, image 2 of 2
      • Locate the fan connector, a 2-pin JST type, from the extruder board on the top of the extruder assembly and while firmly holding the plastic part of the connector, wiggle out the wire.
      • Gently lift the fan off and away from the module. The fan should easily fall out.
      Ask FixBot
    4. UP! Plus 2 Extrusion Head Fan Replacement, Insert replacement fan: step 4, image 1 of 2 UP! Plus 2 Extrusion Head Fan Replacement, Insert replacement fan: step 4, image 2 of 2
      • Place the replacement fan on the extruder assembly in the right orientation.
      • Connect the cable make sure that it has a solid connection.
      • The fins of the fan should be directed to blow torwards the hot extruder shown in the picture, not away.
      • Secure the fan by screwing the top screws back into place in a clockwise rotation.
      • Finish by putting the plastic top back on.
      Ask FixBot
valerie boyer
508 Reputation
4 Guides authored
Cal Poly, Team 14-31, Maness Fall 2014 Member of Cal Poly, Team 14-31, Maness Fall 2014
CPSU-MANESS-F14S14G31
4 Members
60 Guides authored
1 Guide Comment
I have a problem with my UP PLUS 3D printer and I really need your help. First printer started to stop in the middle of the printing, then got to the point where I wasn’t even able to connect it to my laptop (it didn’t recognize it) and now, when I press Print, before even slicing completes, the software crashes and I have to reopen (basically I can’t print anything as every time I try, same thing happens). The weird part is that sometimes I can adjust the bed, heat up extruder, extract or retract filament from software but the moment I press print, it dies. PLEASE HELP!!!
Nima - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 1,174
