Up to 20% off select tools
Guides
Documents
Background
The Shark Rotator Powered Lift-Away Speed is a 2-in-1 cleaner featuring an upright vacuum mode and a portable Lift-Away. This product is manufactured in China and was first released in 2015. This product has 4 different models, NV680-683. The difference between the models are the tools that are included with the vacuum. The NV681 model features, Hard Floor Hero, Pet Multi-Tool, and Duster Crevice Tool which enhance the performance of the vacuum. The Shark Rotator Powered Lift-Away vacuum can become flat in order to clean under couches and tables. It can also becomes portable in order to make cleaning easier, especially when vacuuming stairs.
Comparatively to other Lift-Away vacuums, the Powered Lift-Away Speed is the most compact and light weight. Similar models include Shark Rotator Slim-Light Lift-Away (NV341), the Shark Rotator Lift-Away Professional (NV501), the Shark Rotator Powered Lift-Away Deluxe (NV751), and the Shark Rotator Powered Lift-Away XL Capacity (NV755). You can tell the models apart by the color of the vacuum, as each of them are different colors.
Identification
This vacuum can be identified by its green plastic body with contrasting accents and a silver extension rod. The Shark logo is printed on the top front of the main body and along the handle. The model name, Rotator Speed, is printed on the lower part of the vacuum body. You can find the model and serial numbers printed on the back or bottom of the device, as well as on the original packaging.
Additional Information
Author
with
Dakota Rodriguez-Ransom
623 Reputation
2 Guides authored
Cal Poly, Team S4-G6, White Fall 2018 Member of Cal Poly, Team S4-G6, White Fall 2018
CPSU-WHITE-F18S4G6
4 Members
60 Guides authored
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 103
All Time: 10,145
