Up to 20% off select tools
Guides
Documents
Background
The Saitek X52 Pro is a HOTAS (hands-on throttle and stick) joystick and throttle combination simulation controller made by Saitek. It is designed for use with space and flight simulators. The Pro is the Saitek X52’s successor and includes an LCD (liquid crystal display) to show in-game data, a dual-spring centering mechanism with a metal cone that is designed to allow quick direction changes (the X52 uses only a single spring mounted vertically). Because of the dual-spring centering mechanism, the stick becomes more resistant to movement as it moves farther from the centered position.
The X52 Pro includes illuminated ‘critical’ buttons on the stick and throttle to help users quickly find the right buttons. The LCD display features adjustable backlighting and gives users the ability to view and interact with in-game radio stack information with a few popular flight simulators. The throttle features adjustable tension and includes detents (physical markings indicating where certain actions activate, such as an aircraft’s idle, afterburners, and reverse thrusters). The joystick can be twisted to control an aircraft’s rudders, but this function can be locked to disable the twist function and confine rudder control to the X- and Y-axes.
Identification
The name “X52 Pro” is printed in capital letters in several locations on both the stick and the throttle controllers. The name “Saitek X52 Pro” is printed in white font in the upper right-hand corner of the throttle controller, above the LCD screen.
The Logitech X52 Professional is the rebranded version of the original Saitek X52 Pro H.O.T.A.S. (hands-on throttle and stick) manufactured by Saitek, featuring Logitech "G" branding in the lower left-hand corner of both the throttle base and stick base. "X52 Professional" is printed on both the top right corner of the throttle base and the left-hand side of the stick grip, stylized in all caps.
Note: It is unclear whether there are any differences in the construction of the Logitech and Saitek versions of the controller apart from cosmetics. Caution should be used when using guides interchangeably until more complete information is available.
Technical Specifications
Part Number: 945-000022
Physical Specifications:
  • Stick:
    • Length: 6.7 in (17 cm)
    • Width: 6.7 in (17 cm)
    • Height: 10.9 in (27.8 cm)
    • Weight: 2 lbs (905 g)
    • Cable Length (Power/Charging): 4.6 ft (1.4 m)
  • Throttle:
    • Height: 7.5 in (19 cm)
    • Weight: 1.6 lbs (728 g)
Controller Specifications:
  • Connection Type: USB
  • USB Protocol: USB 2.0
  • USB Speed: Full Speed
  • Indicator Lights (LED): Yes
  • LCD Display: Yes
  • USB Ports (Built-in): No
  • Backlighting: Yes
Product Includes:
  • X52 Pro Stick Unit with USB Connector Cable
  • X52 Pro Throttle Unit with USB Connector Cable
Flight Simulation Software Compatibility:
  • FSX - Flight Simulator X (PC only)
  • X-Plane 10(PC and Mac)
  • Prepar3D® 2.2(PC only)
  • Most Other Flight Simulation Software
Minimum System Requirements:
  • Windows®: 7, 8.1, 10
  • 1x USB 2.0 Port
Additional Information
Saitek X52 Pro Installation Manual
Logitech X52 Professional HOTAS User Guide
Logitech X52 Professional HOTAS User Guide (EN, FR)
Author
with
Cri Cri
632 Reputation
1 Guide authored
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 149
All Time: 21,894
