Up to 20% off select tools
Saitek X52 Pro Disassembly
Views: 33K
View statistics:
Past 24 Hours:
8
Past 7 Days:
55
Past 30 Days:
296
All Time:
33,178
Comments: 28
3 comments on steps, 25 guide comments.
Go to guide comments
Completed: 22
22 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Saitek X52 Pro is a great Flight System Controller, however it is not without flaws.
For me as well as for some other users, the shooting trigger sometimes stops working. This doesn't mean you have to throw it away, instead with a little bit of patience, you can fix it yourself.
    1. Saitek X52 Pro Disassembly, Get your tools: step 1, image 1 of 1
      Ask FixBot
    2. Saitek X52 Pro Disassembly, Open the Joystick - Unscrewing: step 2, image 1 of 3 Saitek X52 Pro Disassembly, Open the Joystick - Unscrewing: step 2, image 2 of 3 Saitek X52 Pro Disassembly, Open the Joystick - Unscrewing: step 2, image 3 of 3
      • Please take a moment and note how your joystick is assembled and all the parts that can be dettached. I recommend taking a few photos before dismantling it.
      • With the Phillips screwdrive unscrew the #1 to #4 screws in Fig. 1.
      • Using the Torx T10 head, unscrew the #5 (Fig. 1), #6, #7 and #8 screws (Fig. 2)
      • Screws 5 & 6 have a larger thread pace than 7 & 8, although the heads are the same. So please take care when you screw them back on (Fig. 3).
      • Using your hand, unscrew #9 (Fig. 2). Please note that you cannot completely remove this screw, but you don't need to do this anyway.
      Ask FixBot
    3. Saitek X52 Pro Disassembly, Open the Joystick - Removing the bracket and the cover: step 3, image 1 of 2 Saitek X52 Pro Disassembly, Open the Joystick - Removing the bracket and the cover: step 3, image 2 of 2
      • Carefully remove the plastic bracket and the support holding the "Pinkie trigger" by pushing it towards the trigger (Fig. 4).
      • DO NOT force its removal, or you can break it.
      • Be careful not to break the Pinkie trigger wire!
      • Remove the stick cover that will expose the contacts and wiring (Fig. 5)
      Ask FixBot
    4. Saitek X52 Pro Disassembly, Fixing it: step 4, image 1 of 1
      • Note the small metal plate.
      • Bend it just a little from the middle so that pushing the trigger actually pushes the small blue switch inside the stick.
      • Test the trigger before putting back the plastic cover
      • Remember when screwing the screws that 5&6 go to the bottom sides and 7&8 go at the top.
      Ask FixBot
      • Note: Inside the trigger there is two screws which can be used instead of either extend or retract the pin that presses the metal plate. Try adjusting this first.
      Ask FixBot
22 other people completed this guide.
Author
with
Cri Cri
632 Reputation
1 Guide authored
25 Guide Comments
Amazing this is what I was exactly looking for!! My trigger stopped work but only heard a single click. Once i opened it up one of the contacts was stuck down. A little adjustment and once again it was working. Getting the hand guard off was very tricky. I did damage the cable guide thing for the pinky switch but it still works. Thank you soo much!!!
Mathew Smith - Reply Share
Glad it helped you! It appears to be a common fault with this joystick.
Sorry to hear about the damaging cable, but I imagine is fixable if it breaks over time.
Cri Cri - Reply Share
Fixed it!! Thank you so much for this guide! I ended up over bending it and then tried to straighten it out again and then it shot off somewhere, but luckily the piece fits back in and then i tweaked it until it worked! -Nate
nenglish87 - Reply Share
This helped a great deal! The Thumb POV had a screw that dropped out and prevented it from going left. By using this I found out why it wasn't working by disassembling it and solved my problem. Thanks!
Arthur Moyer - Reply Share
I was kind of hoping this would be a full Disassembly, as i have much more intricate problem with mine.
Paul - Reply Share
Past 24 Hours: 8
Past 7 Days: 55
Past 30 Days: 296
All Time: 33,178
