Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Note
If you have a Saeco coffee maker, also take a look at the guides for Philips and Gaggia machines. They are all made by the same manufacturer and have a very similar design. Some components are identical in many cases, such as the pump, drain valve, heater or motor.
Background and Identification
Released in 2012, the Saeco Intelia HD8752 is a high-end automatic espresso machine produced by Philips. With its stainless steel design, the HD8752 has a high-quality look and provides greater durability for a long-lasting performance. Moreover, the HD8752 has ceramic grinders that allow for a consistent grind without overheating the coffee bean—avoiding the burnt taste. The ceramic choice also aids in the machines long-lasting performance and allows for silent operation.
Technical Specifications
  • Espresso technology:
    • Saeco adapting system
    • Aroma-system: pre-brewing
  • Supported coffee types:
    • Ground coffee
    • Whole coffee beans
  • Water pressure in pump: 15 bar (perfect espresso)
  • Removable brewing group: Yes
  • Country of origin:
    • Designed in Italy
    • Made in Europe
  • Cord length: 80 cm
  • Number of water boilers: 1 boiler
  • Power: 1850 W
  • Boiler material: Stainless steel (Inox)
  • Cleaning and maintenance:
    • Automatic coffee circuit rinse
    • Descaling cycle
  • Usage:
    • Adjustable coffee dispenser
    • Cup holding surface
    • Rapid steam
    • Normal/long espresso option
  • Product weight: 8.9 kg
  • Water tank capacity: 1.5 L
  • Maximum cup height: 130 mm
  • Product dimensions (L x D x H): 256 x 340 x 440  mm
  • Coffee bean capacity: 300 grams
  • Waste container capacity: 10 servings
  • Features:
    • Cappuccinatore
      • Brews seven coffee varieties
      • Stainless steel
      • Automatic milk frother
    • Hot water/ Steam Nozzle
    • Simultaneous brewing
    • Brita Filter compatible:
      • Optionable
      • Yes
  • Color: Stainless Steel/Balck
  • Materials and finishing: Stainless Steel/ Plastic
  • Energy saving: Automatic stand-by
  • Service: 1-year guarantee
Additional Information
Philips Product Page
Support Page
Philips Saeco Intelia Class HD8752/23 Automatic Espresso Machine Brochure
Philips Saeco Intelia Evo HD8752 HD8881 User Manual
Philips Saeco Intelia Class HD8752/22 Automatic Espresso Machine Product Information
Philips Saeco Intelia Type HD8752 Quick Instructions (EN, IT, DE, FR, ES, PT)
Philips Saeco Intelia Evo HD8752/HD8881 Espresso Machine Instructions
Philips Saeco Intelia Type HD8752 Operating Instructions
Philips Saeco Intelia HD8752 User Manual
Philips Saeco Intelia Class Metal HD8752 Espresso Machine with Milk Frother Specifications
Philips Saeco Intelia HD8752/61 Automatic Espresso Machine with Cappuccinatore Specifications
Author
with
Jean T
724 Reputation
1 Guide authored
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 156
All Time: 14,205
