Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Razer Wolverine Ultimate is a controller that was first released in August of 2017 with the intention of being a professional grade controller for the XBOX one and PCs. This controller is boasted to be better than previous models with its ergonomic build, interchangeable buttons, directional pads that can be swapped out as well as much anticipated dynamic Chroma technology. Common issues with this controller are known to be face button sensitivity and connection issues.
Information
The Razer Wolverine Ultimate can be identified by the model number RZ06-0225 located on the back of the controller along with the device name and serial number.
Technical Specifications
Compatibility: XBOX One, PC (Windows 10)
Connectivity: Wired USB connection
Audio: 3.5mm audio port for stereo output and microphone input
Buttons:
  • 2 HyperResponse Multi-Function Bumpers
  • 4 HyperResponse Multi-Function Triggers
  • 4 tactile switch ABXY action buttons
  • 4-button Quick Control Panel
D-Pads: Interchangeable D-Pads
Thumbsticks: Zero-slow-turn concave analog joysticks with interchangeable caps
Lighting: Multi-Color Razer Chroma lighting strip
Cable: Detachable 3m/ 10ft braided fiber cable with Micro-USB connector
Features: Trigger stops, Carrying case and Quick-release cable
Dimensions:
Length: 106 mm / 4.17 in
Width: 156 mm / 6.14 in
Height: 66 mm / 2.60 in
Weight: Approximately 272 g / 0.6 lbs (without cable)
Additional Information
Razer Wolverine Ultimate Officially Licensed Xbox One Controller
Razer Wolverine Ultimate Review
Author
with
Cerena Jones
195 Reputation
1 Guide authored
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 170
All Time: 1,636
