Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Guides
Documents
Background
The Philips Respironics System One REMstar is a CPAP (Continuous Positive Airway Pressure) therapy device developed by Philips Respironics to treat obstructive sleep apnea and other sleep-related breathing disorders. CPAP machines work by delivering a continuous stream of pressurized air through a mask, which helps keep the airway open while the user sleeps. This treatment is widely prescribed for individuals who experience interrupted breathing during sleep, a condition that can lead to fatigue, cardiovascular complications, and other health concerns.
The System One product line was introduced as part of the Philips Respironics' effort to improve comfort and usability in sleep therapy devices. The REMstar models in this series include features designed to automatically adjust air pressure, monitor therapy data, and improve humidification control. Many versions of the System One REMstar can be paired with heated humidifiers to reduce dryness and irritation during therapy.
Because CPAP machines are used nightly and often for many years, maintenance and occasional repair may be necessary to ensure consistent performance. Device pages like this one help users identify their equipment and locate repair information to extend the lifespan of their medical devices.
Identification
The Philips Respironics System One REMstar is a compact CPAP device typically in a rectangular plastic enclosure with rounded edges. The device generally features a small display screen and control buttons located on the top surface, allowing users to adjust therapy settings and view operational information.
The unit is commonly paired with a removable humidifier that attaches to one side of the device, forming a larger combined unit. Most models are gray or dark gray in color and have a distinctive curved front panel where the air outlet connects to the CPAP hose.
The model number and regulatory information can usually be found on a label located on the bottom of the device. This label may include the product name, serial number, and specific model designation within the System One series. These identifiers are important for confirming the exact model when searching for repair guides or replacement parts.
Users can also distinguish System One REMstar devices by their distinctive airflow outlet design and the modular humidifier attachment system that allows the humidifier to be detached when not needed.
Technical Specifications
Common technical specifications for the Philips Respironics System One REMstar include:
  • Device Type - CPAP therapy device
  • Manufacturer - Philips Respironics
  • Primary Function - Treatment of obstructive sleep apnea
  • Pressure Range - Typically 4-20 cm of water (depending on model)
  • Display - Integrated control panel with LCD display, keypad, and dial
  • Humidifier Compatibility - Optional heated humidifier attachment
  • Power Supply - External AC power adapter
  • Data Tracking - Therapy compliance and usage data recording
  • Connectivity - Some models support SD card data storage for therapy monitoring
  • Dimensions - Compact tabletop medical device design, 7 in x 5.5 in x 4 in (18 x 14 x 10 cm)
  • Weight - Approximately 3-4 pounds depending on configuration
  • Filters - Reusable foam filter with optional ultra-fine disposable filter
  • Data Storage - Therapy data stored on SD card
  • Sound Level - Less than 30 dBA during operation
  • Ramp Time - 0-45 minutes (5-minute increments)
  • Therapy Modes - CPAP (some versions also support Auto-CPAP/APAP)
  • Model Differences - DS550 is the System One 50 Series, an earlier version of this device and the DS560 is part of the newer System One 60 Series, which introduced improved compatibility with updated heated humidifier systems and other incremental hardware improvements. These model numbers can usually be found on the label located on the bottom of the device, along with serial number and regulatory information.
Additional Information
The following resources provide additional helpful information about the Philips Respironics System One REMstar:
CPAP shop Product Page
Philips Support Page for Sleep Apnea
Philips Respironics System One REMstar User Manual
Sleep Apnea Information on Devices
Philips Official Product Information
Author
with
Justin Ogihara
31,780 Reputation
52 Guides authored
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 119
All Time: 3,683
