Philips Respironics System One REMstar Blower Unit Replacement
  1. Philips Respironics System One REMstar Blower Unit Replacement, Blower Unit: step 1, image 1 of 1
    • Turn the device upside down so that the rubber feet are facing you.
    • Use the TR15 screw head to remove the two 46.5mm length crews located on the back.
    • Gently remove the casing so that the wires are not damaged.
    Ask FixBot
  2. Philips Respironics System One REMstar Blower Unit Replacement: step 2, image 1 of 1
    • Using a Torx TR10 screwdriver, remove the seven 13.5 mm screws that are securing the inner casing.
    • Remove the inner casing.
    Ask FixBot
  3. Philips Respironics System One REMstar Blower Unit Replacement: step 3, image 1 of 1
    • Remove the motor from the bottom half of the inner casing and set it to the side.
    Ask FixBot
  4. Philips Respironics System One REMstar Blower Unit Replacement: step 4, image 1 of 2 Philips Respironics System One REMstar Blower Unit Replacement: step 4, image 2 of 2
    • Remove the circular piece by popping it off to separate the circuit board from the top cover.
    • No tools should be necessary to complete this action.
    Ask FixBot
  5. Philips Respironics System One REMstar Blower Unit Replacement: step 5, image 1 of 2 Philips Respironics System One REMstar Blower Unit Replacement: step 5, image 2 of 2
    • Disconnect the green and red wire connectors from their white connectors to disconnect the blower motor.
    Ask FixBot
3 other people completed this guide.
2 Guide Comments
These steps may be out of sequential order. Step 4 should probably be Step 1 and perhaps some are even missing.
Charles Marshall - Reply Share
very helpful. but where to buy the blower motor. or what lubricant is suitable is suitable for the blower bearing.
my email: kiankokk@hotmail.com
kenny - Reply Share
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 41
All Time: 2,023
