Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Arc 3 has introduced a bunch of new editions since its original release in 2008, there have been 11 different models of the Arc 3. Specially designed by Panasonic, the powerful Arc3 3-blade system combines pure shaving velocity with multi-blade precision to cut gently and comfortably through facial hair. The shaving machine system's ultra-thin Nanotech blades are forged from premium stainless steel. And, each is precisely honed to a 30° angle for outstanding durability and sharpness to cut whiskers at the root for fast, smooth, efficient shaving.
The Panasonic Arc3 ES-LT3N-S Wet/Dry Men's Electric Razor combines pure shaving power with the gentle comfort and convenience of multi-blade shaver precision. A floating 3-blade system provides quick, smooth shaving while an advanced 3D multi-flex pivoting shaver head glides over face, chin, jaw, and neck. Hypoallergenic stainless steel blades, honed to a 30-degree angle, can cut whiskers more cleanly at the root, and a pop-up trimmer instantly engages on the cordless shaver to cut stray hairs and detail sideburns and mustache. The 13,000 cpm fast, linear motor drive system eliminates the tugging and pulling that can occur with slower machines and also maintains high power right up to the end of each battery charge. Plus, with its 100 percent washable, wet/dry versatility, you can confidently use the Arc3 men's shaver in the bath or shower, over the sink, and on the go.
Identification
The is black with some red accents. The Panasonic brand logo is printed towards the bottom front of the handle in white. You can find the model and serial numbers printed on a label on the back of the razor. For additional help finding the identification numbers, take a look at the Panasonic site.
Additional Information
Panasonic Arc 3 on Amazon
Panasonic Arc3 ES-LT3N Official Site
Panasonic Arc3 ES-LT3N-S Owner's Manual
Author
with
Andrew Trainor
648 Reputation
5 Guides authored
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 68
All Time: 3,072
