Panasonic ARC ES-LT3N Battery Replacement
    1. Panasonic ARC ES-LT3N Battery Replacement, Back Casing: step 1, image 1 of 2 Panasonic ARC ES-LT3N Battery Replacement, Back Casing: step 1, image 2 of 2
      • Flip the razor over so the back is facing you.
      Ask FixBot
    2. Panasonic ARC ES-LT3N Battery Replacement: step 2, image 1 of 2 Panasonic ARC ES-LT3N Battery Replacement: step 2, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the 6 mm screw just above the charger port.
      Ask FixBot
    3. Panasonic ARC ES-LT3N Battery Replacement: step 3, image 1 of 2 Panasonic ARC ES-LT3N Battery Replacement: step 3, image 2 of 2
      • Slide the plastic cover at the bottom of the razor downward to remove.
      Ask FixBot
    4. Panasonic ARC ES-LT3N Battery Replacement: step 4, image 1 of 2 Panasonic ARC ES-LT3N Battery Replacement: step 4, image 2 of 2
      • Lift up the rear casing from the bottom of the razor.
      • This may require you to gently pry it apart with you fingers.
      • Lift up the rear casing from the sides of the razor.
      • Pull rear casing up and off razor.
      • Be careful not to break any plastic!
      Ask FixBot
    1. Panasonic ARC ES-LT3N Battery Replacement, Battery: step 5, image 1 of 1
      • Using the Phillips 00 driver bit, remove six screws (12mm) from the battery case.
      Ask FixBot
    2. Panasonic ARC ES-LT3N Battery Replacement: step 6, image 1 of 1
      • Remove battery case.
      Ask FixBot
    3. Panasonic ARC ES-LT3N Battery Replacement: step 7, image 1 of 2 Panasonic ARC ES-LT3N Battery Replacement: step 7, image 2 of 2
      • Remove old battery by lifting the battery up and left.
      • There are plastic brackets holding the battery on the right. Removing up and left ensures that the brackets will not be damaged and the battery will not come loose.
      Ask FixBot
2 other people completed this guide.
Andrew Trainor
648 Reputation
5 Guides authored
1 Guide Comment
Where does one actually find the replacement batteries though?
WooKstah - Reply Share
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 45
All Time: 2,480
