Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Description
The Native Instruments Komplete Audio 2 is a popular audio interface for musicians, podcasters, and producers. It features a minimalist design and easy-to-read VU meters on the top panel. The device is fully USB bus-powered and does not require an external power supply.
Identification
The Komplete Audio 2 is part of a series of interfaces that share a similar look. Here is how to distinguish them:
  • Komplete Audio 1: Features only one XLR input and RCA outputs on the back.
  • Komplete Audio 2 (This Device): Features two combo inputs (XLR/Jack) on the front and two balanced 6.3mm (1/4") jack outputs on the back.
  • Komplete Audio 6 MK2: Is significantly larger, features four analog outputs, MIDI ports, and two headphone jacks.
Technical Specs
  • Audio Quality: Up to 192 kHz / 24-bit
  • Inputs: 2x XLR/Jack combo with 48V phantom power
  • Outputs: Stereo Out (2x 6.3 mm Jack), 1x Headphone Out
  • Connection: USB 2.0 Type B
  • Dimensions: 140 x 112 x 52 mm
  • Weight: 360 g
Model History
  • Released: January 2019
  • Model Number (MPN): 26148
  • Generation: Released alongside the Komplete Audio 6 MK2, this device is not designated as "MK2" itself, as it is the first version released under this specific name.
Common Issues
  • USB Port: The USB-B port is a known weak point and may become loose or break off due to mechanical stress.
  • Potentiometers: Scratchy volume knobs may occur after prolonged use.
Author
with
Kris Rodriguez
322,559 Reputation
1 Guide authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 54
All Time: 876
